91 Civic SI ecu code
sorry if i posted in the wrong place. my 91 si threw a check engine light today and the ecu blinked
1 blink
1 blink
4 blinks
andone tell me what it is? dont think its code 114 cause i cant find anything for it!
im not too familure with ecu codes and stuff, thanks!
1 blink
1 blink
4 blinks
hey buddy check out this stuff here.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/%5Bfaq%5D-ecu-codes-trouble-shooting-468260/
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/all-ecu-codes-you-will-ever-need-1710584/
that has a list of codes for our ECU's and should tell you how to diagnose it.
if you have PM6 ECU, you have a code 1 for O2 sensor and a code 4 for crank sensor (in the distributor) - PM6 ECUs do not have long and short blinks, only short
thanks, thats probably it. i have a sohc JDM ZC engine but ive read you can use the factory harness and ecu from the SI wich is what i have, si it should be PM6. is there a blink between each code or sometin?
