SRS Light
Old Sep 11, 2011 | 07:55 PM
bennyBronco's Avatar
Default SRS Light
I have an s2000 steering wheel on my 5th gen that was installed by the previous owner. The air bag wiring do not match up so I do not have an airbag on my driver side. Does anyone know how to disable the light? Somehow turn the light off?
Old Sep 12, 2011 | 05:34 AM
97ludedude's Avatar
Default Re: SRS Light
other than fixing the problem that is causing the air bag code. . . no real way that i know of to turn off the light except for just pulling the bulb out of the cluster. maybe look for the srs relay / fuse and pull in but i bet that will not work.
Old Sep 29, 2011 | 07:11 PM
is it tru that the cruise control will not work if the srs light is on? cause my cruise control is wired up but not working.
Old Sep 29, 2011 | 07:49 PM
preludeNApower's Avatar
You can put a two ohm resistor across the connector to fake out the system to think there is an airbag plugged in.
Pulling the fuse will not work.
barfo
Mar 5, 2018 04:31 PM
sohag.hossain
Honda CR-V & Element
Jan 23, 2018 08:52 AM
slixxracing
Nov 13, 2013 05:49 PM
OneFire
15
Apr 14, 2004 01:27 PM
