Summer and Winter Tires, what to do in the fall and spring
Old Sep 11, 2011 | 06:40 PM
Atomic1's Avatar
Default Summer and Winter Tires, what to do in the fall and spring
For those of you running Summer and Winter Tires, what the heck do you do in the spring and fall? I decided to try out summer tires for the first time this year and we just hit our first rainy day in the 50's and I thought I was going to skid off the road...but obviously its still too warm to swap on the winters...I'm thinking allseasons may actually have a purpose in this respect. do you run a third set of tires?
Old Sep 12, 2011 | 04:32 AM
toyomatt84's Avatar
Sanji
Default Re: Summer and Winter Tires, what to do in the fall and spring
Summer tires work fine in Fall/Spring, as long as you don't have inclement weather (ie. snow).
Old Sep 12, 2011 | 07:25 AM
joeshmo's Avatar
You clearly need some fall and spring tires. Would you like to buy a DVD rewinder too?
Old Sep 12, 2011 | 08:34 AM
Atomic1's Avatar
If my summer tires didn't turn into hockey pucks at 50 degrees I wouldn't have posted.....
Old Sep 12, 2011 | 10:08 AM
TunerN00b's Avatar
You can run the summer tires down to nearly freezing, but you will want to let them warm up in cooler weather before trying to push it on them. Driving safely will warm them up just fine in 10 to 15 minutes.
Check pressures often, especially as the temp changes.
Old Sep 12, 2011 | 12:37 PM
donut.'s Avatar
Driving too fast for the conditions maybe? Easy there speed racer
Old Sep 12, 2011 | 01:02 PM
doc@tirerack's Avatar
summer compound tires should be fairly flexible down to about 40 degrees (F) or so..... if your past experience indicates they didn't work well below 50, it may also have been due to a tread depth issue as well.......(especially in wet conditions)
Old Sep 12, 2011 | 02:12 PM
stinkbox's Avatar
I drove last winter on my 280 tread wear neo gens lol. Didn't have 1 single problem even snow covered roads. If you have or can afford winter tires it is definetly recommended though. I have some snow tires on extra wheels this year that came on my last car so we'll so how much better that goes.
Old Sep 12, 2011 | 02:14 PM
TunerN00b's Avatar
Um, the Neo Gen is an all-season tire. Not the same thing as a dedicated summer tire, which is what is being discussed here...
Old Sep 12, 2011 | 05:04 PM
Atomic1's Avatar
FWIW, These tires are BF Goodrich G-force sport with about 6,000 mi on them. The worst was when it was lightly raining and about 50 degrees...at worst 45 degrees on asphalt. The car was nearly paralyzed at stop lights, like I was driving on ice. I basically had to start in 2nd gear. While moving at about 45 mph I would feel the rear end meandering. Complete loss of front end traction when making a right hand turn at normal speed. Scary as heck for only being September.
Old Sep 12, 2011 | 06:24 PM
joeshmo's Avatar
Wow, that doesn't sound at all natural for any kind of tire. I've driven summers in the winters and they are bad but not that bad.
Old Sep 13, 2011 | 12:36 AM
rickyislazy's Avatar
all season tires are the way to go, summer tires are a waste of money
Old Sep 13, 2011 | 09:45 AM
TunerN00b's Avatar
Some of us live in areas where the temperature never gets below 45*. All season tires would be a waste in such an area.
The variety of tires exists because everyone's needs are different.
Old Sep 15, 2011 | 05:25 PM
sde780's Avatar
I find this hard to believe. I drove in many storms on bald Kumho AST and if I drive normal there's no issues. What motor do you have? I can see myself not having traction from a stop if I had an H22 or something
Old Sep 25, 2011 | 07:28 PM
Atomic1's Avatar
Its just a stock B16. Dont know what to tell you. At one point I had a semi truck next to me at the light (in the rain as mentioned above) and I essentially had to match his acceleration to keep from biting it...all the while thinking this is crazy how bad these tires are. Over the past few weeks it appears the magic temperature is about 50. Traction is obviously far worse on asphalt rather than concrete.
Although I enjoyed these tires over the summer, man I'm wishing I had my allseasons again now to get me through november.
Old Sep 27, 2011 | 01:01 PM
TunerN00b's Avatar
For what it's worth, I had a set of all season tires that were that bad in the wet. One freeway onramp I couldn't get the car to move forward, as the tires would spin with any throttle applied. I had to let the car roll backwards to a flat section and take a running start at the ramp.
But, those were "adequate tread, but aged out" tires. Rubber gets hard as it gets old, and doesn't drip the same. Mine were 7 years old at the time (according to the sidewall date, I'd only had them for 3 years), and were past their usable lifespan.
Check the date on your tires, and make certain that they haven't aged out.
Old Oct 3, 2011 | 08:04 AM
jdmcivicracer89's Avatar
Umm u might wanna stop dumping the clutch then. There is no way ur spinning that much with a stock b16 in rain. Try this slight throttle and realease clutch slowly garanteed u wont spin. Hell on dam ice i can move without spinning tires. U just need to get off from mashing the throttle and slow it down before u hurt urself or anyone else on the road. My .02
Old Oct 5, 2011 | 06:43 PM
Atomic1's Avatar
Tires are only 2 years old, looks good. No clutch dumping, thanks for the obvious advice.... i'm not the one who totaled my 00 si.
Old Oct 5, 2011 | 07:37 PM
sde780's Avatar
Because other people can't possibly total your car
Old Oct 5, 2011 | 08:00 PM
wstmsol's Avatar
lulz
Old Oct 6, 2011 | 05:27 PM
Haha u asked the question i gave u the response.. Ive never caused any accident its called f250 rearending u and shoving u into a crown vic and making ur nice em1 turn into a crx.. Nice try though
Old Oct 6, 2011 | 05:28 PM
Naw no way that can happen ha
Old Oct 7, 2011 | 07:07 AM
FlewByU352's Avatar
Solution, move to new location where the weather doesn't suck. 85 degrees on October 7th, going to the beach this weekend... this is livin the life.
Old Oct 7, 2011 | 08:20 AM
Atomic1's Avatar
A snarky assumption deserves one in return.
Lucky! I keep telling the wife this.
Old Oct 7, 2011 | 10:33 AM
TunerN00b's Avatar
Well there's the problem...
(I have the same issue...)
hybridshooter
Nov 23, 2008 09:32 AM
Kamikaze Royale
Suspension & Brakes
Jan 25, 2007 10:53 AM
LilManSi
Dec 1, 2003 02:49 PM
CW_97_ITR
Jan 28, 2003 01:05 PM
KENLUDE97
Jan 20, 2003 07:41 PM
