B18c block with b16 head timing gear
Old Sep 11, 2011 | 06:12 PM
TehTaylor's Avatar
Default B18c block with b16 head timing gear
I have a b16 head that i am about to put on a b18c block, but the block is missing the cranks timing gear. which crank timing gears can i use for this set up? And what are the torque settings for the head onto the block with arp head studs? any help would be appreicated thanks.
Old Sep 11, 2011 | 10:08 PM
NotAJDMFanBoy's Avatar
Default Re: B18c block with b16 head timing gear
All B series should be the same. Depending if you're using the weird OBD2 crank sensor determines which you can use. OBD1 has a plain gear, OBD2 has a gear with teeth on the back for the sensor. I'd look up the part number for the B16 to verify if something will work.
All B series crank pulleys are interchangeable. The snout diameter is the same. The TDC mark is always going to be the same.
You are limited to B series parts I believe. D series crank pulleys and gears are smaller and H/F/K are larger.
pascualito
Sep 23, 2008 05:03 PM
Power Rev Racing
Sep 8, 2005 12:16 PM
tgreaves
Dec 28, 2004 07:06 PM
rondigs
Feb 10, 2004 06:54 PM
