99 Civic Ex Turbo Help
I installed a greddy turbo kit for a 92-95 civic on my 99 ex and i was just wondering if i should run the p2p ecu with the e-manage or should it be the obd1? Cause whenever i start it, idle goes up and down.. That's with the obd1 to e-manage.. I also checked for boost leaks but there was none.. E-manage is set on 5psi on stock internals.. I'm still on my stock injectors btw if that matters.. Much help would be appreciated. Thanks in advance!
car_mo_na_po
Sep 11, 2011 07:04 PM
