97 honda accord h23a no fire
Old Sep 11, 2011 | 01:18 PM
h22accord101's Avatar
Default 97 honda accord h23a no fire
i got a 07 accord h23a swapped but is getting no fire. i converted it to a obd1 harness with a obd2 to obd1 ecu harness. and the harness is external coil and the car is internal but no fire. and ive replace the distributor and everything internal to the dizzy but nothing and the fuel pumps kicking on so dnt beleave the main relays bad. ive checked the trans, manifold and valve cover grounds and all are secure so im at a stopping point so any thoughts welcome.
Old Sep 11, 2011 | 08:07 PM
rival12's Avatar
Default Re: 97 honda accord h23a no fire
07? or 97?
Very Different. Does it crank?
Old Sep 13, 2011 | 04:12 PM
sry 97 and yea itll turn over just no fire and fuel pump is kicking on and ive replaced the distributor and made it internal coil withnew coil cap button plugs and wires and still nothing. only thing is be4 i replaced that stuff it had a msd external coil and i started it up and had a lil miss so i thought i wired it up wrong so i switched the 2 wires and that ended up being wrong and it fried the coil and i havent got fire since.
Old Sep 15, 2011 | 06:53 PM
i talked to a few friends and they say to check the coil hot wire and see if its getting a signal if it isthen most likely its the coil but if its not getting any signal then they think its my ecu so do i check with ign on or turn the car over any thoughts on this
Old Sep 17, 2011 | 04:11 PM
ok ive check the hot wire to coil and it has no power when ign on or turning over and the distributor plug has ground but no power to anywires could this be the ecu or any other possable things. all the fuses r good
SiRCD5
Jul 14, 2014 05:35 AM
darrinirox
Jun 8, 2011 07:56 PM
97LXF20B
Oct 9, 2007 09:49 AM
