CA: FS/FT Fresh Built ITR/CTR LSD Transmission
Contact: Joel 909 728 9967
Price: SOLD$1150 w/core $1450 w/out ( shipping additional )
Item: Y21/Y80/S80/S4C US 97-01 ITR JDM 95-97 ITR JDM 92-00 SiR/CTR US 93-97 Del Sol LSD Transmission
Warranty: 1yr 12,000 miles
Verified Gear Ratio(s):
Verified Tooth count(s):
***1st-------2nd----------3rd--------- 4th---------5th--------- FD (4.4 )
ms: 13-------ms: 19-------ms: 24-------ms:28------ms: 33-------ms: 15
cs: 42-------cs: 40-------cs: 35-------cs: 31------cs: 28-------cs: 66
Tumbled & Cleaned Casings - Fully Cleaned, Clearance Checked & Inspected
* ALL New GearSpeed Carbon 1-5 Synchros
* ALL New Synchro Springs
* ALL New OEM Bearings - Differential also
* ALL New OEM Seals
* Replaced CounterShaft
* Replaced Ring Gear 4.4
* Replaced CS 1-2 sleeve
* Replaced MS 3-4 Sleeve & Hub
* Replaced Friction Dampers
Trades I'll Consider:
15x8 or 15x9 6UL's
Dual core Ek half size w/ slim fan
Stage 1 clutch kit d-series Hydro
Virgin or Socketed P28
liquid fuel psi gauge
D-series Fuel psi regulator
Obd2a - 1 jumper harness
Wideband O2 with gauge
Scatter shield
D/B-series LSD
D-series cam stage 1/2
D-series Adj. Cam gear
D-series performer x IM
B-series 62mm TB
- 1st 3.230
- 2nd 2.105
- 3rd 1.458
- 4th 1.107
- 5th 0.848
- Rev 3.000
- FD 4.400
* ALL New OEM Seals
15x8 or 15x9 6UL's
Scatter shield
D/B-series LSD
B-series 62mm TB
Bump for good price. Cost a little cheaper than what a used japan transmission will cost and the benifit of this one its that its been rebuilt.
Depends on what's wrong with it. Using basic kits (bearings 1-5 synchros seals ) rebuilds start @ $550 ends OCT 1st.
