Anyone used Crower Stage 3 cams?
Old Sep 11, 2011 | 07:47 AM
EF Ian's Avatar
Default Anyone used Crower Stage 3 cams?
I was wondering if anyone has used Crower Stage 3 cams and if so how did/do you find them?
I have a set which I got as part of a deal which I will be using in a built B20 but I've found it hard to find info on them and I might consider swapping to Buddy Club Spec IV's
Old Sep 11, 2011 | 11:56 AM
JR_Integra's Avatar
Default Re: Anyone used Crower Stage 3 cams?
I have them in my B18c build. The stage 3 cams are their full race cams, the part number is 63403-2.
Lift both intake and exhaust is .468 inches for the vtec lobe. Duration at .050 is intake-263 and exhaust-255 on the vtec lobe.
Here is the link for more info on these cams
http://www.crower.com/camshafts/acur...-per-pair.html
Old Sep 11, 2011 | 01:33 PM
EF Ian's Avatar
Thanks for the Link, lift isn't as high as I thought, they would probably do a good job except I don't need cams that make power that high, My build should take 8800rpms no problem but I wasn't planning on taking it past 8600.
Is this a build thats still in progress or is it one thats just been completed? I guess since you didn't say how you feel they perform its still in progress.
Old Sep 12, 2011 | 12:32 PM
JR_Integra's Avatar
I just finished it and got it running a few weeks ago. It still hasn't been tuned, but from driving it around the block on a very rich base map, it seems to have more low end grunt than my previous engine.
As for the rpm range, I don't plan on taking my engine above 8500. I selected the 63403-2's because it had a very broad effective range (1250-9750) and could be used in later engine builds if I build something more radical.
Old Sep 12, 2011 | 02:04 PM
EF Ian's Avatar
Thanks again for your views.
Need to make my mind up now.
Old Sep 12, 2011 | 07:17 PM
JR_Integra's Avatar
No problem, glad I could help.
BigDare23
Aug 1, 2009 02:28 PM
shorejdm5
Jan 7, 2008 06:24 AM
Ruben19
Jan 24, 2006 07:25 PM
teamexcel
Nov 1, 2004 06:14 PM
ricebowl
Oct 28, 2004 11:27 PM
