gsr harness????
i have a gsr harness. its obd 1. on the pass side by the shock tower the harness has 4 plugs. i know the 3 big ones clip in. but theres a 4th plug. what is it? were does it go? its a small 2 wire plug. any ideas. i tryed searchin but nothing. help me!!!!!!!!!!!!!!!!
wires are red, yellow/black. its on the engine harness. idk what year it came out of but its obd1. please help!!!! car wont start wondering if these wires have something to do
Car cranks but will not start, or car will not crank?
The only yellow/black I can think of is the output of the PGM-FI Main Relay, [fuel injector relay] to fuel injectors. ECU/ECM, and a few engine solenoid/valves.\
I will have to check farther.
My 94 is not a GS-R so it only has the 3 plugs. 94
the car cranks and turns over. just no start. if its for evap i dont need it. the motor is in my 92 hatch. i thought the plug had more to do with it. idk?????
Ditto what HondaPartsHero said. it is for the "Evaporative Emission Purge Control Solenoid Valve", [evap purge valve]
The yellow/black is 12V+ when ign. switch is in run or start positions and comes from the injector relay in the PGM-FI Main Relay, the red is the ground control from the ECU/ECM, [PCS output].
Have you checked the obvious things, do you have spark, do you have fuel, do you have compression, is the timming correct, both valve timing and ign. timing? 94
gezer
Aug 28, 2004 11:33 PM
