Swapping cylinder heads
Old Sep 10, 2011 | 08:33 PM
dk4ever's Avatar
Default Swapping cylinder heads
I have a USDM H22a1 making 184 whp and 144 wtq right now. I came across a Euro-R/Type-S cylinder. Wondering if it would be worth swapping it over to the USDM bottom end with a Stage 2 cam?
Old Sep 12, 2011 | 05:27 AM
97ludedude's Avatar
Default Re: Swapping cylinder heads
Pretty sure the head is the same, just different cams.
Old Sep 12, 2011 | 07:19 AM
minilogoguy18's Avatar
PDE heads have a different valve angle, they might have a slight port job from the factory but that part I'm unsure.
Old Sep 12, 2011 | 08:03 AM
andoxviii's Avatar
My 2001 Prelude SE has a PDE head stock from the factory.
Are you sure the PDE head is the Euro-R/Type-S?
Old Sep 12, 2011 | 09:58 AM
There are differences in the red top and US heads but pretty sure the valve angle is the same, also has a different lost motion assembly but your US head definitely doesn't have any sort of port job done to it.
Old Sep 13, 2011 | 06:54 PM
dk4ever's Avatar
This is true. They have different valve angles and a factory port job like the ITR's& CTR's.
Old Sep 13, 2011 | 06:56 PM
dk4ever's Avatar
The one I have is a JDM Euro-R cylinder head. It came off my Euro-R bottom end.
Old Sep 15, 2011 | 11:27 AM
CA121's Avatar
i'm sure the valve angle is the same, the seats have a different angle cut, they have type s cams and a factory port job.
Old Sep 15, 2011 | 09:20 PM
dk4ever's Avatar
Ok so with that being said. Will the factory port job in combination with a stronger aftermarket cam in the Euro-R head benefit my usdm bottom end? I'm trying to see if anyone has done a swap like this already and if the gains are worth the swap.
kyky
Honda Civic (2006 - 2015)
Jul 29, 2017 01:36 PM
Chino Chaplin
Apr 30, 2015 04:44 PM
polakking
Jul 14, 2004 04:01 PM
BryanPendleton
Mar 3, 2004 12:28 PM
AussieK24
10
Oct 13, 2003 04:50 AM
