Recommended master cylinder for my race setup.
Old Sep 10, 2011 | 02:57 AM
0NE600's Avatar
Default Recommended master cylinder for my race setup.
Hi Every one.
I am currently running AP 4 Piston front brakes and also running 4 pistons in the rear. Car stops very strong but the pedal feels like crap as I am still using stock EF crx booster and master.
Any recommendation I what would significantly improve the pedal feel?
I am currently leaning towards the Chase Bays Brake Booster Eliminator w/ Dual Outlet Master Cylinder.
Would like to hear other peoples opinions.
Thanks!
Old Sep 10, 2011 | 03:49 AM
turbohatchBnuts's Avatar
Default Re: Recommended master cylinder for my race setup.
I heard the chase bay one works really well.
Old Sep 10, 2011 | 10:47 AM
.Manny.'s Avatar
Touching My Member
civic ex 15/16" master.
Old Sep 10, 2011 | 11:05 AM
dc5itracer's Avatar
90-91 civic ex booster and 15/16th master cylinder
Old Sep 10, 2011 | 02:13 PM
redsolturbo's Avatar
15/16th cylinder wont cut it. its the same as our uk spec VT's come with on 262mm front calipers and 242 rears.
you need a 1 inch cylinder form an integra type R or you can also here in the uk find them on MB civic vti's (come with a b18c4 dohc vtec engine) tend to go for the £40-80 gbp mark on ebay including the larger brake booster (its a different fit form the stock vt and 16v non vtec boosters). im running one on mine and they are miles better than a 15/16th on multi pot and larger brakes.
Cheers
Old Sep 10, 2011 | 02:29 PM
DCRB's Avatar
the 1" master cylinder also came on prelude vtec's with 11" front brakes
Old Sep 10, 2011 | 03:29 PM
0NE600's Avatar
Thanks for your replys. Looks like I will be going for the chasebays 1inch master setup
Old Sep 11, 2011 | 12:12 AM
Tyson's Avatar
just curious, how did you fit those 4 piston calipers on?
knuckles? adapter bracket? rotor?
Old Sep 11, 2011 | 03:14 AM
0NE600's Avatar
The rear, we Cnc custom brackets. For the front it was an eg6 brake kit. I had to use eg6/Ek4 knuckles to make them work
Old Sep 11, 2011 | 06:30 AM
You have a eg knuckle on your ef?
Old Sep 11, 2011 | 09:51 AM
Tyson's Avatar
you got more issues than MC size then...
Old Sep 11, 2011 | 02:46 PM
turtleman321's Avatar
Thinking the same thing lol
Old Sep 11, 2011 | 03:23 PM
.Manny.'s Avatar
Touching My Member
I run an 11" wilwood 4 piston kit up front and integra rear discs with an EX master cylinder, stock Si booster, and a 4040 prop valve. My brakes feel great and the car stops even better than great.
Old Sep 11, 2011 | 06:46 PM
freydaddy's Avatar
i think with that MC, the fittings match up exact. (91 Prelude)
Old Sep 12, 2011 | 03:38 AM
0NE600's Avatar
yes I do was in my mind the easiest way to make these brakes fit.
what makes you say that?
EJAYATE
May 2, 2008 08:47 AM
duh blacksheep
Apr 24, 2005 11:09 AM
Tommy_Gunns
Dec 7, 2002 09:49 PM
