Question on drum to disc conversion 92-95 Hatch
is it possible to take off the rear drum brake assembly on a 92 Hatch and just install the GSR rear disc, calipers, etc on the original Civic trailing arm? Or would i have to swap out the Civic Trailing arm/drum brake assembly for a GSR Trailing arm/disc brake assembly?
Thanks.
Thanks.
yes you can swap them onto a civic trailing arm, thats the only way i do the conversions because there is no need for a alignment afterwards, there are 4 torx bolts and one large nut of the back of the spindle, just remove those, and put on the integra stuff in the same fashion along with ebrake cables
MugenHonda
Jun 12, 2003 05:14 PM
