My teg, not too special but i tried
Old Sep 9, 2011 | 03:54 PM
94VTEC2TONE's Avatar
Default My teg, not too special but i tried
THE CAR WAS STOLEN, PROJECT OVER.............................................. .
Well heres how she started out and some progress, nothing as crazy as some of you guys but i did my best for the exp i had at the time, made tons of mistakes that i have now learned from i guess, car would be way better had i set a real plan out. But heres some info on it
THIS IS HOW I TOOK HER HOME
SOME MORE OLDER PICS
AFTER THE FIRST TIME IT WAS PAINTED
AFTER SOME BODYWORK, SHE STILL LOOKS ****ED UP THOUGH.
BEFORE THE REMOVAL AND THE WIRING
TAKING OUT SOME OF THE SOUND DEADENER, AND TRUNK
AFTER THE ABS REMOVAL AND SOME OF THE WIRING
SOME MORE PREP WORK, GETTING CLOSER TO BEING DONE
JUST SOME RANDOM PICS
MODS:
Hytech replica header
2.5 exhaust/resonator with a hytech twinloop muffler
Blox Intake manifold
Hondata Intake manifold gasket
3inch shortram with velocity stack, cai would make more power
Blox type A cams
PS and AC delete
Itr throttlebody
Function and Form type 1 coils
bunch of weight saving via multiple items removed
DYNO AFTER CAMS, with a 2.75 intake not the 3inch currently and only the ws2 exhaust
Best track times before suspension,new exhaust and some added weight savings
15.02@ 94 or 95mph
2.4 60ft
Cars not fully together yet but im assuming with the coils new exhaust and some of the weight savings that the car mite be able to do a mid low 14. But ive lost the drive to really keep the modding going
Old Sep 9, 2011 | 08:20 PM
Default Re: My teg, not too special but i tried
Ill try to post some more pics sometime this week, trying to get this thing painted i just gotta get off my *** and sand the rest of the parts. Probably going to be just DD the car for a bit and selling it after and starting with something new
Old Sep 10, 2011 | 09:02 AM
CShep92's Avatar
looking forward to seeing how this ends. have you set out a plan for it yet? or are you still going with the flow.
Old Sep 10, 2011 | 09:52 AM
(. )( .)'s Avatar
hey man looks great, keep it up, the quarter panels look great, I wanna straighten out my 1/4's also, how much time and work was it each?
Old Sep 10, 2011 | 10:31 AM
Well the cars been down nearly 8months maybe even more because i tore it apart completely had no plan of attack and work was cutting hrs so i had no money to keep the progression as fast as i needed it to be.
When i took it apart my plan was to clean it up and try to atleast make it look better because it had stock suspension and took a beatin from the salt.
I took off the ws2 exhaust, i swapped it with 2.5 exhaust 12" resonator and a Real hytech muffler(VBAND axleback ftw) which you can see in one of the pics how it sits.
It has Function & Form type 1 coilovers no camber kits. It took a little while adjusting these to get to see exactly how i wanted it to sit and im still not done.
SUSPENSION:
So my suspension setup is as follows: Function 7 lcas, asr subframe brace, beaks tie bar, Function&Form type 1 coils. The only prob is the 23mm swaybar is not in the rear anymore because of the bolts that mounts the bushing snapped in the backing plate, ohh what a dam problem. So itll stay like that till i get a replacement backing plate.
ENGINE:
140k mile stock gsr block
Blox intake manifold with hondata IM gasket
ITR throttle body
Blox A's cams
3inch shortram for now with a bpi velocity stack
2.5" exhaust with hytech muffler
hytech replica header
arp headstuds, cometic headgasket
12lb i believe lightweight flywheel
Comp stage 2 clutch
WEIGHT REDUCTION:
no spare tire, jack or emergency equipment stuff
No rear seats, upper or lower. No rear seatbelts or brackets
Pass airbag removed
AC and PS removal,
All sound deadener removed, not for those who like quiet cabins thats for sure
abs delete, man that unit is heavier than youd think
evaporator deleted
No abs module in the car along with all the harness equipment that goes to it
BODY MODS:
All rear emblem holes shaved, rear antenna hole shaved
rear wiper deleted
side molding shaved
front emblems shaved
also have a vacuum and oil pressure gauge in my quad pod made gauge pod as you can say. Just havent gotten a sandwich plate for it yet.
The quarters look okay but not near as great as some of your guys cars, your best bet is to buy new quarters for that perfect oem look. It took my old man a long long time to reshape them to even look decent, he hated doing it.
Ive lost alot of steam on this project between money and things not going exactly how i want it too.
Pretty much the plan is to finish sanding the parts and prepped for a flatblack primer sealer, put all the panels back in, find the parts that i put away 8months ago and drive it because it sucks not having the teg on the road, atleast ill have a good month with it im hoping.
Ive driven the car a few times and after all the wiring coils and other **** ive done the car seems to pull just as hard if not harder than before, spins 2nd if i choose 2(not saying its making a ton of power by any means) but for what it is its not bad. Brakes just as good if not better than before. I havent driven it far because it has no bumpers or plates on it so i do some vteccing aroudn the streets and sneak on home lol
THIS IS HOW BAD IT WAS:
PICS OF THE SUSPENSION
Old Sep 10, 2011 | 08:14 PM
CShep92's Avatar
that sucks man, planning on getting a new teg afterwards?
Old Sep 11, 2011 | 02:34 AM
russ.shafer's Avatar
its looking good. but i dont understand why ur running 15s. i have a 94 teg gutted its stock ls just 4to1 header ran a 14.9
Old Sep 11, 2011 | 04:55 AM
CF_EM1's Avatar
looking good man keep it up
Old Sep 11, 2011 | 04:47 PM
Ridewithme38's Avatar
I like the change to the Clock section in the dash...i'd love to hear what you did there
Old Sep 11, 2011 | 04:53 PM
I do not plan on gettin anymore tegs, as much fun and problems i have i want to start fresh with a new platform, maybe a evo 8 or 08 gti. she was a hell of a project from the get go and i knew nothing then hence why progress was so ****in halfassed.
I never really launch the car hard, with the innovative 75as i couldnt launch higher than 2k or i would just rip the **** out of the tires. I was also on 140k mile stock suspension that had such lift and drop i think it didnt help at all.
I did nothign but bolt it up, That is a CLOCK POD by QUAD POD, just put the gauges in and go. only word of advice is if you stick it with the 3m tape he gives you be super careful removing it because i pulled 2 hard and seperated both parts, that was my fault. Vac gauge on the left, elec oil press on right, aint hooked the press up because no sandwich plate and now idk if i even wanna do anymoe to it,
If i could run the car in 2 weeks id think it would cut low 14s
Im seriously contemplating selling this car and starting over
Old Sep 11, 2011 | 06:35 PM
OrangeTeggy's Avatar
finish it
Old Sep 12, 2011 | 01:09 PM
CShep92's Avatar
would love to see the teg finished but an evo would be cool too.
Old Sep 12, 2011 | 06:01 PM
itll get painted and be running no worries, but im definetely looking at selling it after
Old Oct 1, 2011 | 10:39 AM
Its not perfect but i didnt expect that, theres a fun runs that gotta be fixed, rest of parts to be painted but overall not too bad
AND I HAVE DECIDED I WILL BE SELLING IT WHEN ITS BACK TOGETHER AGAIN IN A FEW WEEKS. JUST DONT WANNA DO HONDAS ANYMORE.
Old Oct 1, 2011 | 03:35 PM
KinDx's Avatar
looks good man.
how was it painted?
satin black, right?
sucks you are going to sell it, good luck
Old Oct 1, 2011 | 06:33 PM
KinDx its a hotrod flat black, i guess it kid of looks satin. It was painted by a paintgun not aerosol cans or anything. Waiting to get the rest of the parts painted and a few mistakes fixed.
It dont suck to me trying to sell it, i just wanna start over with a different platform and hope i can get what i want for the car when all is said and done. I know the next owner will enjoy it
Old Oct 1, 2011 | 07:58 PM
nick88's Avatar
good work, but not diggin the flat black
Old Oct 2, 2011 | 04:59 PM
well i am, and i got tired of white
Old Oct 8, 2011 | 07:08 AM
Getting closer to being done, and prepped for sale
Old Oct 19, 2011 | 04:10 AM
Car is gettin resprayed this week, found a few parts i needed. pretty much gotta put on the splash shields and a few other things and shes ready to be driven again
Old Oct 20, 2011 | 06:38 PM
EG6_LS_BOOST's Avatar
you use primer in that color
Old Oct 21, 2011 | 04:12 PM
i have no idea what your trying to say with that post. But you can prime something many colors. This is a hotrod black primer not aeresol bullshit or anything.
BTW the cars going to be for sale here shortly, just curious what kind of offers you think this car could bring? i have a mod list if anyone is really interested, But the newest things are the coilovers and the hytech twinloop muffler with about 5miles on them
Old Dec 15, 2011 | 06:43 AM
UPDATE, Well the car was ****ing stolen so this project is over
Old Dec 15, 2011 | 07:22 AM
MIEj1's Avatar
WHAT?! Dude, that honestly sucks big *****, I'm sorry to hear that
Old Dec 15, 2011 | 10:27 AM
that suck
