wheel offset and lip
Old Sep 9, 2011 | 03:26 PM
morrow921's Avatar
Icon2 wheel offset and lip
hey i was wondering does the wheel offset creat the lip or does the offset seperate from the lip and they both together make the wheel deeper or what help me out please
Old Sep 9, 2011 | 04:02 PM
It Wasn't Me's Avatar
Default Re: wheel offset and lip
https://honda-tech.com/forums/wheel-tire-56/9658-forum-rules-faq-read-before-posting-1188922/
What is offset?
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. It determines how much the wheels stick out from the car. The best offset depends on your particular car as well as on the width of the wheels. As a general rule, you *should* be able to get away with an offset between +35-45, but you will have to check what others have used for your car's year, model, and version to be sure. More info: http://www.tirerack.com/wheels/tech/offset.jsp
Old Sep 13, 2011 | 12:34 AM
rickyislazy's Avatar
they are both factors
Old Sep 14, 2011 | 01:11 PM
Chunkylover8200's Avatar
will a 15x8 wheel with a +25 offset poke out more than a 15x7 wheel with the same offset?
my guess would be yes, and by half an inch, but im a noob lol
Old Sep 14, 2011 | 02:15 PM
toyomatt84's Avatar
Sanji
Yes. And, indeed, by 1/2". Since the wheel is an overall inch wider and the measurement for the offset is from the center of the wheel, you have to divide the width change in half.
Old Sep 15, 2011 | 02:31 PM
thanks man
Awsom-o 4000
Suspension & Brakes
Apr 19, 2009 12:45 PM
F20Cdriver
Oct 13, 2008 08:16 PM
smash fascism
Apr 10, 2005 10:50 PM
PressurizedSi
Sep 17, 2002 08:04 PM
