Rear lower tie bar question
Old Sep 8, 2011 | 08:40 PM
whiteteggy44's Avatar
Default Rear lower tie bar question
Hey Honda tech,
I have a question, if I run a benen rear lower tie bar and function 7 LCAs. Will I have to buy new, longer LCA bolts or will the oem ones be long enough to accept both?
Thanks in advance.
Old Oct 3, 2011 | 10:02 AM
Default Re: Rear lower tie bar question
Anyone?
Old Oct 3, 2011 | 01:37 PM
GagnarTheUnruly's Avatar
The LCAs don't affect anything. I believe the problem arises when people try to install both a Benen bar and some other brace (like an ASR brace) at the same time. If you're just using a Benen bar I think the stock bolts work fine, but I'm not sure.
Old Oct 3, 2011 | 01:44 PM
Ok thanks man, anyone else who has tried it?
Old Oct 3, 2011 | 03:32 PM
arialdrone's Avatar
this should be correct....should.
Old Oct 3, 2011 | 10:54 PM
Thanks guys! Anyone else have any input?
Old Oct 4, 2011 | 12:49 AM
From what I understand the function7 lca's are a lot thicker than oem ones. Would that make the bolts come up too short?
Old Oct 4, 2011 | 06:11 AM
kyden's Avatar
they are thicker in the middle, if they were thicker at the bushing ends they wouldn't fit on the car, lol.
EGeezy
Nov 17, 2014 08:07 PM
jlowellintegra
Sep 22, 2010 07:18 PM
SD_EM1
Jun 10, 2004 11:28 PM
Train
May 6, 2004 09:49 PM
GR_DC2
Feb 5, 2004 04:29 PM
