Looking for aem ems v2 info
Where is a good place to find more info on the aem ems v2? There site doesn't seem to have a lot of info. I was told the it would do close loop fuel trims but can you set your target afr differently at different load/rpm parameters? can it control water meth injection? Also can you hook the egt probe striaght to the ems or do you have to have some sort of controller prior to the ems inputs? And just other random things I'd like to know about the system. A good site or link to a GOOD info page would be cool if someone would care to take the time to help me out here.
Your best bet is to download the AEM tuner software: http://forum.aempower.com/forum/index.php
It will show you everything it can do :-)
Go here to download AEMTuner
http://forum.aempower.com/forum/inde...c,26751.0.html
These instructions will be loaded with the installation of AEMTuner
Basic information on the 30-6060
C:/Programs/AEM/AEMTuner/Instructions/10-6060 for EMS - 30-6060.pdf
If you have the latest AEMTuner it will also install manuals for the EMS-4. This is for the EMS-4 however it tells you how to tune and make adjustments to a number of functions in the EMS that they never really explained before.
C:/Programs/AEM/AEMTuner/Instructions/ EMS-4 Install and Tuning Guide_Rev 1.7
If you install AEMPro
Just a good read on the basics of Fuel Injection
C:/Programs/AEM/AEMPro/Instructions/AEM EFI Basics V1.3.pdf
The other thing about calibrations not loading. OPen up AEMTuner and go to open a calibration. Navigate to the area in AEMTuner under calibrations. Than Honda/Acura. It most likely will not display anything which is what I think you are seeing however look at the bottom Files of type: Change this to All Calibration Files and there you go.
Ok cool thanks. I'll check it out and see what I can come up with. What from I can tell alot of the tables are set up similar to that of hptuners. Which I used for a long time on gm stuff, like my tahoe.
CaptainBuster
Engine Management and Tuning
Sep 26, 2014 07:27 AM
NewOrleansH22
May 3, 2006 03:31 PM
