d16y8 swap in 89si
you will need to convert to obd1 for vtec to work
you will just need to bolt your tranny up to it
use a jumper for dizzy and ecu (p28)
wire up vtec
wire up vtec
You can use either your stock Si injectors or the Y8 injectors.
The only difference being that if you chose to use the Y8 ones then you will have to do an injector resistor box delete.
Have you even looked at anything you are trying to do?
Look up saturated vs. peak and hold injectors... You tell me what suits your application. Obviously using the stock injectors would be easier...
Obviously the alternator plugs are different... So use your A6 one. You need to search better all these answers can be found in the FAQs...
I would use the Y8 injectors because they are newer, but that's just me.
Using your Si ones will not make a difference as far as operation goes.
You can use either alternator, but you will need an adapter (or get the appropriate plug and wire it in yourself) to get the Y8 one to work.
http://www.rywire.com/catalog/obd0-o...pter-p-34.html
<old man gibberish omitted>
saturated vs. peak and hold injectors <old man gibberish omitted> stock injectors would be easier...
<old man gibberish omitted>the alternator plugs are different<old man gibberish omitted>all these answers can be found in the FAQs...
hey sorry im a little confused can some1 please help out, my car is obd0 and the d16y8 i got off a 99 civic ex and some people told me to convert it to obd1 but others say that the 99 civic ex is a obd2.....should i still convert obd0 to obd1? idk im a newb, so confused
You can convert to obd1 best thing to do u just need a 92-95 dizzy and ecu p28 and jumpers for both rywire has everything u need check out that link that was provided
i have a p28 but its auto, i seen online to convert it to manual just take out resistor 17 and 18 and put a jumper across 18, is that correct? but i also seen some1 that took off the transistor for ic15 and 16? but every1 online just say to take off the 2 resistors?
dizzy just has to fit the head idk wich one will
you cant use the y8 dizzy unless you convert to obd2 witch is a waste of time
and the auto thing idk
use the y8 dizzy and convert the dizzy plugs to the obd2 plug. that's it.
clutch and fly will match your transmission
here's how to convert auto to manual ecu conversion
http://hondaswap.com/~pills/autotomanual.html
yeah my y8 is the complete long block, and the ecu is from the same car, so if i just get the adapter it should work? what about the intake manifold should i use the si or y8?
