Do brands matter when it comes to LCA's?
I see that Blox LCA's run about $130 and Skunk2, F&F run $215-$250. Is there any difference between materials and quality when it comes to these or is it just in the name?
Having not used either one of the brands mention I am not going to rule either way.
But to answer the title of your thread. All things are not created equal so YES brands can matter. I have seen LCAs break on other vehicles and I am sure some of the cheap china ones are not made to the standards of the nicer ones. LCAs are something that if you broke one it could be very dangerous. I would not skimp here.
Function 7 uses a higher grade aluminium than any of the other aftermarket lcas manufacturers, they also have the option of spherical bearings, which is a big plus considering the extremely low quality of most aftermarket lca bushings. They're the only LCA other than stock I would run on my car.
Ultimately, they are really just cosmetic, but so are a lot of other things we put on our cars. Performance should be the first priority, but that doesn't mean you need to ignore cosmetics.
i have blox on my ej1 they are **** the bushing was destroyed in less than 2 weeks of normal driving.
if you want the best bushing get HARD RAce or Function 7 lca. they are th best.. could eeven get the omni if you can find them.
im running blox... bushing tore in about 6 months...
got the bushings replaced with soft pu bushings.. daily driven 2 months and a track day, still fine...
as for the bushings, the guy who i did it with said hes been using the soft pu bushings in various parts of his EF for about 5 years now and no issues.
guy_from_nerk
39
Aug 1, 2008 12:13 PM
P@@RB@Y
Jul 3, 2006 06:23 PM
It says they are corrosion treated dunno if that will make a difference in winters.
