93 accord electrical issue
My corner lights, cluster back light, and running lights next to the brake lights are all down. I checked all the bulbs and they are fine except the cluster because i havent taken the dash apart..and the 15a fuse that controls it popped so i replaced it and when i turned the lights on the fuse popped again now this sounds like a short somewhere but any idea where to start? Help please
You probably have a short in the circuit. Try checking the red/black wire circuit that runs along the main wire harness to see if some part of the insulated wire has been burned, cut, etc. and touching metal ground or a ground wire.
Steven.
Oct 7, 2006 01:04 PM
