F/S: Parting out ALOT of b-series parts from an EF
Old Sep 7, 2011 | 04:12 AM
88YellowRexSi's Avatar
Icon5 F/S: Parting out ALOT of b-series parts from an EF
I'm parting out a ton of parts from my EF. No reasonable offer will be turned down.
Go here for the list of parts with pics and other info:
http://www.auto-xcessories.com/partsforsale
PM me, or email me at slammin_s10@hotmail.com
I can take cash, check, Visa, Mastercard or Discover.
ABS Intake
90-93 Accord Tranny
ACT Clutch
ACT Flywheel
AEM Fuel Rail
EF Alternator
Axles
Apex-i Twin Chamber BOV
B16 Block
Block Girdle
Block Guard
Brake Booster
Cast Turbo Manifold
Catch Cans
ACL Crank Bearings
Crank Shaft
Crower Turbo Cams
Crower Springs & Retainers w/ OEM Valves
Denso MAP Sensor
OEM Oil Dipstick
DirectHits
TD44-U Distributor
EACV
Eagle H-Beam Rods
Fast Idle Valve
Flex Pipe
FMIC
Green Valve Cover
Hasport Mounts
Hasport VTEC Subharness
B16 Head
Head Studs
Silicon Couplings
Hondata Intake Gasket
94-01 Integra Gauge Cluster
B-series Intermediate Shaft
Locash Racing OBD0 to OBD1 ECU Harness
Lost Motion Assemblies
Tenzo-R Lower Arm Brace
MAP Sensor
10# NOS Bottle
4-wire O2 Sensor
OBX Fuel Rail
OEM Cam Gears
OEM Differential
OEM Differential w/ Final Drive Gear
OEM Fuel Rail
OEM Fuel Injectors
OEM Intake w/ Throttle Body
OEM Rocker Arms
Oil Cooler
Oil Filter Adapter
Polished Intake
Purge Solenoid Assembly
RC Engineering 440cc Injectors
Rear Motor Mount Bracket
Rebuilt Tranny w/ LSD
Red Valve Cover w/ Cam Gear Cutouts
CRX Gauge Cluster
ACL Rod Bearings
Hondata S200 & P28 ECU
Starter
68mm Throttle Body
Stainless Steel T-clamps
Spark Plug Wire Cover
OBD0 Cable Speedometer
ACL Thrust Washers
Timing Belt Covers
TPS Sensors
T3 Turbo
Turbonetics Cast Manifold
Turbo Oil Flanges
Venom Cam Gears
YS1 Tranny Case
Old Sep 7, 2011 | 07:07 AM
Default Re: F/S: Parting out ALOT of b-series parts from an EF
ttt
Old Sep 7, 2011 | 08:27 AM
forceinducted's Avatar
hey do you have the brake and clutch pedal for the ef? if yes how much shipped to 60181? thanks!
Old Sep 7, 2011 | 12:19 PM
maxwellmercer's Avatar
How much for the td44u shipped?
Old Sep 7, 2011 | 04:07 PM
I do, but I need it...
Old Sep 7, 2011 | 04:09 PM
$70 shipped anywhere in the US...
Old Sep 8, 2011 | 02:59 AM
ttt
Old Sep 8, 2011 | 03:59 PM
ttt
Old Sep 9, 2011 | 05:05 AM
ttt
Old Sep 9, 2011 | 05:55 PM
OnlyJosh's Avatar
Bottom priced shipped on the Hasport Mounts? Pm me price plz.
anthonysed3
May 25, 2012 06:34 AM
88YellowRexSi
Sep 9, 2011 05:05 AM
henrettatc
Feb 11, 2009 11:05 AM
91EF_Si
Northeast (Sales)
Jun 24, 2008 08:39 PM
