Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2002 Odyssey Flashing "D"
Old Sep 6, 2011 | 03:25 PM
JupiterOdyssey's Avatar
Default 2002 Odyssey Flashing "D"
My 2002 EXL drive indicator started to flash. I had it scanned with an OBD II scanner and the code was P1740 indicating a 4th gear pressure switch. I looked on the net for some info and came across this thread https://honda-tech.com/forums/honda-minivans-crossovers-trucks-80/04-odyssey-flashing-drive-light-2497831/ . The fix seems simple enough so I called the dealer for the part. The part they quoted to me was 28600-P7Z-003 assuring me its for the 4th gear switch and not 3rd (since I asked), but everywhere I looked, that part is for a 3rd gear switch and the 4th gear switch part is 28600-P7W-003. Can anyone confirm the actual part number for the 4th gear switch? Thanks.
BTW, its for a 2002 EXL with over 218,000 miles on the original transmission.
Old Sep 22, 2011 | 02:21 PM
dealer_tech's Avatar
Default Re: 2002 Odyssey Flashing "D"
I hate to give you bad news but that sensor is probably fine and is not seeing enough psi. Most the time if we get a code like that on a trans with over 60k on we replace the trans per Honda. I hope this works for you Its just have replaced hundreds of these trannys and know most do not stand the test of time.
Old Sep 22, 2011 | 09:28 PM
90sedan's Avatar
From looking at online part catalogs, it does look like they gave you the 3rd gear pressure switch.
I really hope you aren't replacing transmissions for a p1740. This is a dtc for a problem in the 4th gear pressure switch circuit, so either switch, wiring or pcm failure, nothing inside the transmission.
Old Sep 22, 2011 | 09:47 PM
Don't want to argue just passing along what I have seen, and it does have 200k on a know problematic trans. I would put the switch in and see what happens, I'm by no means telling him to run out and buy a new trans. And Honda does have us replace these trans for lessor problems, just because of the problems they had and class actions brought against them. This is all from a warranty stand point.
santhon2
Dec 17, 2010 06:13 AM
sacalait59
May 19, 2010 04:27 AM
4DRmafia
Feb 16, 2009 01:48 PM
Idz21
Jul 12, 2007 07:20 AM
dabiddan
Nov 20, 2004 12:12 PM
