JRSC with BTC and MAP Controller jerking letting off gas
Old Sep 6, 2011 | 12:16 PM
anthony415's Avatar
Default JRSC with BTC and MAP Controller jerking letting off gas
I have a Blox FMU 12:1 and 6PSI pulley with the JR BTC and MAP controller.
When I let off the gas it sometimes has a little jerk, I thought it was the engine mounts so I replace those with energy mounts. Mechanic thought it was misfiring so change the timing to 18 degrees.
Where should the JR BTC set to? Does my set up with Blox FMU 12:1 work? I don't want to move to Hondata because I'm in California.
1997 Acura Integra GSR
Old Sep 6, 2011 | 08:17 PM
Turbo-LS's Avatar
Default Re: JRSC with BTC and MAP Controller jerking letting off gas
FMU Thats all that needs ot be said, GET IT TUNED !!! You can get an AEM FIC to piggyback on the stock ecu and tune the car
Old Sep 6, 2011 | 08:24 PM
anthony415's Avatar
California it won't pass smog with any AEM or Hondata
Old Sep 7, 2011 | 04:27 AM
Turbo-LS's Avatar
it will pass smog with a hacked up fmu but not a piggyback controller that allows the car to run on stock ecu and be scanned with OBD2 scan tool?
Old Sep 7, 2011 | 07:04 AM
anthony415's Avatar
Forgot the JR MAP controller won't either. Is it ok to run fuel enrich relay with Blox 12:1 or JR FMU 5:1?
Which is better Blox 12:1 or JR FMU 5:1?
Old Sep 13, 2011 | 11:04 PM
anthony415's Avatar
figured out my problem Blox 12:1 too much fuel
johnnymass
Mar 22, 2011 01:45 PM
KaoticBrd
Oct 4, 2007 02:03 PM
PickleTeg
Sep 7, 2006 01:37 PM
tsjeff
Dec 27, 2005 01:49 PM
iguano
Dec 2, 2004 02:13 PM
