ls/vtec oil leak
Old Sep 6, 2011 | 12:11 PM
hatchyboy89's Avatar
Default ls/vtec oil leak
hey i just built a ls/vtec and i have a small oil leak in the front corner trans side,i thought it was cuz i was using a ls dizy but i fixed that leak,does anybody have any idea,
please help
Old Sep 6, 2011 | 01:30 PM
jdmcivic2fast's Avatar
Default Re: ls/vtec oil leak
I see no leak!
Old Sep 7, 2011 | 09:27 AM
there is it starts on the corner ill try and get a better pic.
Old Sep 7, 2011 | 11:35 AM
93egSLEEPER's Avatar
That is known around the honda community as the "VTEC leak". You need to honda-bond that corner when you put the HG and head on to seal it up. From the factory ive seen that exact leak. So unless you wanna do a HG i suggest you just keep it clean.
Old Sep 7, 2011 | 11:52 AM
negusjuda's Avatar
ahh the infamous left front corner leak lol
Old Sep 7, 2011 | 11:53 AM
on do i have to use honda-bond or can i use sumthing else
Old Sep 7, 2011 | 11:55 AM
honda-bond is ultra grey. Nissan has their own version of it...something rvt, its orange. I have not found anything that works better than ultra grey though.
Old Sep 7, 2011 | 11:37 PM
mouab18c1's Avatar
Is the head torqued down properly? Did you check your VC gasket? Vtec solenoid gasket? Cam plug?
Old Sep 8, 2011 | 10:52 AM
yea head is torqued,new vc gasket and cam seal, i will check the vtec solenoid again
if i do the honda-bond where do i put it,i tryed to find a write up
Old Sep 8, 2011 | 10:56 AM
95 integra's Avatar
When I had a leak there, it was because I had previously installed the HG backwards and thought it would be ok to just reinstall it correctly. Sadly it was creased and leaked....in that very corner. Could be a cam seal or vtec solenoid though...
Old Sep 8, 2011 | 11:30 AM
mouab18c1's Avatar
If the headgasket was on backwards oil would be shooting out like hell in the back of the block. Hondabond is not the solution. I would retorque the head and check all seals again.
Old Sep 13, 2011 | 09:05 AM
silv6rbull3t's Avatar
try checking the vtec solenoid seal
Old Sep 13, 2011 | 10:52 AM
.Manny.'s Avatar
Touching My Member
definitely, it's hard to tell that the leak is coming from there when the oil is fresh and clean.
hatchyboy89
Sep 10, 2011 09:07 PM
buttascotch_3
Apr 16, 2008 04:30 PM
slowteg140
Jun 19, 2005 05:50 AM
91integraLSVTEC
Sep 28, 2003 09:08 PM
iblewmyrmotor
Jan 16, 2003 11:32 AM
