Miata Partout: Garrett, TiAL, Stance, VVT, OS Giken, 3.636...etc universal parts too
Parting out my car. I have been back and forth about this, but even for me to consider it means that i dont feel for the car the way i should. I am buying a 350z.
Loaded pumpkin (not seperating) $2000
OS Giken Differential, 3.636 ring and pinion. Puddymod built stage 2. includes a solid sleeve instead of a crush washer and cryo treated everything.
Stance Coilovers $1000 good condition!
AEM EMS $1000
Injector Dynamics 725's with pigtails $425
TiAL 2871R with 0.86 turbine housing used for 2 weeks, basically new. $1200
TiAL 38mm MS-V with 7psi and 10psi spring $200
Top mount turbo manifold-vband $500
Vbanded 3" exhaust with magnaflow muffler and 3" high flow cat $500
Intercooler/piping setup $200
Toyota COPS with new plugs $80
Custom power steering setup $150 (has pump to an adapter, custom lines, custom resevoir and return line)
Innovate LC-1 wideband with blue guage $200
Mishimoto Radiator $150
Fidanza Flywheel 1.6 $250
ACT Xtreme 6 puck unsprung clutch for 1.6 $250
Modified angle steering knuckles $200
Hydro ebrake $100
Bride Replica seats $800 (pair)
1.8 driveshaft and new 1 peice axles $150
OEM "Roadster" door sills $80
2002 Miata VVT engine $450 valve cover modded with -10an breather hose and milled for COPS
5 speed transmission (good working order) $200
OEM wood nardi steering wheel with hub $200
KG works rear lip spoiler $130
ATP vband catch can $60
GM 3 bar map sensor $60 with pigtail
Xenochron boost control solinoid $40
Muteki extended lug nuts $30 color is the titanium brownish
ARP head studs $75 torqued once to check compression, engine never ran still good shape
Fenders with Japanese side markers $75 BRG, will need paint
BRG doors $60
BRG aluminum hood $60
BRG aluminum trunk $60
XXR 002 $600 15x8 et0 with Dunlop Direzza DZ101
Here are some general pics of my car.
if you want specific pics Email me please.
Matt
m.moore13@hotmail.com
AEM EMS $1000
Hydro ebrake $100
BRG doors $60
Matt
SI_frankenstein
Jan 21, 2012 09:11 PM
bburtonsk8r2
Feb 26, 2008 04:16 PM
opto_isolator
Sep 23, 2004 12:43 PM
