Car wouldn't start
I recently parked my 2000 Honda Accord EX 4 cylinder sedan for a few minutes. When I got back to my car the car wouldn't start. The engine wouldn't turn over and it made a funny low sounding screeching noise, the dash board was dim and the digital read out of the mileage was messed up as I turned the ignition key. The low oil light, battery indicator, door icons, srs and brake icons stayed lit. My radio and A/C still worked. I kept trying it over and over then I let it cool down for a few minutes and the engine finally went on. What is the cause of this? Do I need a new battery? is there an electrical problem? Was it a glitch in the system? I need your thoughts, I don't wanna buy a new battery if I don't need one. Any suggestions?
Yes, test your starter/solenoid or main relay, and yes check the battery too and make sure the connections are clean and the battery can hold a full charge. Has nothing to do with your harmonic balancer (sheesh)
in my case it was the harmonic balancer the rubber bushing behind the balancer wore out so the belts slip give me lights across the board, so laugh youself to sleep, if that makes you happy. Its a common problem with accords call the dealer, just giving him my scearnio, thanks.
multi_2009
Jul 31, 2017 12:18 PM
bribee03
Jun 7, 2010 08:30 AM
ckur1y
Jun 2, 2009 05:26 PM
Slink2000
Jul 21, 2008 05:45 PM
