96 Integra DB7 RS B20B swap question...
Hey HT,
I'm in the process of swapping in a B20B into my 96 Integra RS sedan. I tried searching all over google for my answers before I posted this thread and have had no luck.
I wanted to know if I would still be able to use the LS power steering pump and AC compressor for the B20B?
Also from what I was reading people have switched over from OBD2 to OBD1 to it too run "better" Is this worth doing?
Any advice / input would be greatly appreciated.
Thanks in advance !
Thanks in advance !
your integra is obd 1, you can use your ac compressor and ps pump the brackets are the same, in my case i used my ls crank pulley in order to use the oem part #'s for the belts, if you want to use the b20 pulley get a crv belt for your ps pump
Also I forgot to ask in my original post, I plan to just have an Intake, header, high flow cat and full exhaust. What size piping would you guys recommend?
Thanks again!
Would 2.5" piping effect the low end torque of the B20?
It shouldn't are you going to run a cat or a test/straight pipe?
