Suspension & Brakes Theory, alignment, spring rates....
probably a simple question
Old Sep 5, 2011 | 04:58 PM
camden's Avatar
Default probably a simple question
Putting coils on my EK.
So i bought a set of coilovers for an EF. They came off of an EG.
Rears are on and fine, spaced, whatever.
Trying to use EF forks and they are wayyy too narrow to fit over FLCA.
I thought they bolted up? any suggestions?
Old Sep 5, 2011 | 09:33 PM
98civdx's Avatar
Master Detailer
Default Re: probably a simple question
You can't use EF forks, you already found that out.
Buy 96-00 forks, except SI. They will NOT work, unless you have SI front control arms.
Old Sep 6, 2011 | 07:37 AM
camden's Avatar
im starting to wonder if my FLCA's were swapped to Si arms. because the ef forks were much too narrow. and the set that was on my hatch would not work with the coilovers due to the mounting point of the coilover being too small for the fork.
Do EK forks have a small opening for the strut?
Old Sep 6, 2011 | 02:23 PM
98civdx's Avatar
Master Detailer
Post a picture of the LCA
Old Sep 6, 2011 | 02:37 PM
camden's Avatar
currently I don't have access to tools at school, not sure if its relevant but the lca's are stamped , not cast
Old Sep 6, 2011 | 04:14 PM
98civdx's Avatar
Master Detailer
1 Peice lca? 99-00 SI are 1 peice, and don't have the bolts in the middle as all the others do.
Old Sep 7, 2011 | 08:13 AM
camden's Avatar
i believe they are 1 piece... i keep trying to contact PIC to just buy the lower part of the coilover that the fork mounts to.. but i havent had any success. tried e-mailing and calling
Old Sep 7, 2011 | 02:32 PM
98civdx's Avatar
Master Detailer
What do you you think? it's yes or no.
Do they look anything like these?
http://unlimitedjdm.com/cms/index.ph...mart&Itemid=47
Old Sep 9, 2011 | 09:11 AM
camden's Avatar
yep. ordered replacement cups from PIC,
memo_ej8
May 29, 2013 09:32 AM
turbowagon94
Apr 12, 2011 03:53 AM
cliniCrx
Suspension & Brakes
May 24, 2010 04:58 PM
yellowjdmcrx
Apr 22, 2008 12:59 PM
