Will the f22b1 fit in my accord?
i have an f22b2 in my 96 accord now and i have a bad manual tranny but i have a sohc vtec f22b1 with a manual transmission all together in my garage.
will this fit in my car?
can i pull the tranny and just use it, will it bolt up to my non vtec?
if so is it a hard job?
You can install the B1 as well but you will need the ECU, intake and exhaust manifolds from the B1 the B2 has slightly different ports.
The transmissions are the same and will swap out. It's fairly straight forward, and easy. Honda keeps it pretty simple, if you look in the FAQ section you will find some swap information.
aznevanchoi
Feb 8, 2007 12:51 PM
