Huge Honda sale. Oem and aftermarket parts
Old Sep 5, 2011 | 10:48 AM
protopro88's Avatar
Default Huge Honda sale. Oem and aftermarket parts
I have a ton of parts that have just added up over time and im looking to clean out my garage so these useful parts are not just laying around. Send me an email if you find anything that you want. call/text 608-698-5911 Here are the parts i have for sale:
B-SERIES:
**B18a1 Ls cylinder head (includes cams, valve cover, and all the internals)
*DC 4-2-1 header (not pictured)
*Timing belt cover parts (half or full)
*Throttle body gasket (says its for 2.0 L)
*1999 civic si ecu
*(2)Gsr water pump
*(2)Oil pick up
*(2) sets of cam gears
*(3) oil caps
*Oil pump
*Alternator
*Gsr head bolts
*V-tec solenoid (clip is broken but still has wires)
*Stock B16 injectors
*RC270 saturated injectors (will fit others then b series)
*AEM fuel pressure regulator (will fit others then b series)
*B18 oil pan
*B18 Ls distributer (missing clips but wires are still connected)
*Breather box
*Gsr emissions canister
*Gsr integra Trunk cargo cover (not pictured)
*B16 intake manifold
*Crank pulley
*b18 flywheel
*b18 coolant pipe
*b18 thermostat housing and thermostat
*b18 oil pump
*b18 crankshaft seal
*B18 crankshaft girdle
*b18 timing belt tensioner
*b18 ls Pistons and rods
*Gsr timing belt (looks perfect)
*b18 dip stick tube
*b18 power steering bracket
*b18 crankshaft bearings and "holders"
D-SERIES:
*Civic arm rest (not in the best shape)
*Civic fuel pump
*Automatic D-series transmission (90K miles)
*Manual starter
*Ek hatchback roof wind deflector (may fit other models) Not pictured
ACCORD :
*Valve cover gasket, spark plug tube seals, and grommets
*Almost complete cylinder head gasket set
*Genuine honda roof wind deflector (may fit other models) Not pictured
*passenger side window track (not pictured)
*Window motor (not pictured)
*Door lock module (not pictured)
*Driver door wire harness (not pictured)
*Driver door controls (not pictured)
*driver door handle (not pictured)
Old Sep 5, 2011 | 12:20 PM
ls94civic's Avatar
Default Re: Huge Honda sale. Oem and aftermarket parts
up
protopro88
Oct 26, 2011 04:58 PM
protopro88
Aug 17, 2011 10:46 PM
JENNY_EG6
Sep 2, 2010 08:48 AM
InfamousRS
Aug 24, 2002 08:27 AM
