****what kind of ITB i can use on my 81 civic wagon?????*******
a few years ago on redpepperracing, there was a push toward using bike carbs and that would be a viable option rather than having to figure out some way to make CVCC work with ITB (fuel injection). I have a cheesy diagram of the way I modified a stock CVCC manifold to work with a set of CBR 929 carbs- but that was using a newer, more powerful motor and it was still a bit over-carb'd... then again, I half-assed my actual product to avoid welding and it came out pretty shitty- avoid that by having real welding done.
I'd say a set of carbs from a 400-500cc 4cyl bike would work as long as you can have someone do some good aluminum welding for the new/modified runners.
Good luck on your build, neat wago btw
I like your flares, i have a 83 4dr. Did you make yours or buy them? What lip is that? Killer car though buddy
Seen on the 78 civ thread you are looking into motor swaps. From my understanding you can swap any 80-81 1500 cvcc straight in motor for motor or just a block since your heads the same. Or you can look into the accord 1600, I believe they work as well. The big thing is that you get a long block or stay the same year category as your motor because the 80-81 and 82-83 have different water paths so your not suppose to be able to swap heads and such between them.
hope thats a little in site and gl with the build!
[/IMG]
