97 Accord Dash Shortage?
Old Sep 4, 2011 | 11:11 AM
dlewis2583's Avatar
Default 97 Accord Dash Shortage?
Sup HT,
My dash has been going in/out when driving at night. I have to tap the dimmer switch to get them to come back on. What is the cause of this & how do i troubleshoot/fix this problem? here's a vid of what im talking about:
http://youtu.be/KQu16FS8yZc
Old Sep 4, 2011 | 07:19 PM
jamzx3's Avatar
Default Re: 97 Accord Dash Shortage?
replace that dimmer switch
Old Sep 4, 2011 | 08:04 PM
dlewis2583's Avatar
How do I do that?
Old Sep 5, 2011 | 04:09 AM
sl0waccord's Avatar
Well first you have to buy a new dimmer switch. I would recommend going to a junk yard. They should only be like $10. Next, pull off the plastic panel under the steering column above your pedals. It should be held on by a few clips, it pops off pretty easy. Then stick your hand up behind the dimmer switch and push it out. It just pops out to. Disconnect then the harness, then reverse everything to put it back together. Very easy. Let us know if that doesnt fix it.
Old Sep 5, 2011 | 09:13 AM
dlewis2583's Avatar
heading 2 the junk yard now....
Old Sep 5, 2011 | 02:05 PM
sl0waccord's Avatar
So did you get it fixed?
Old Sep 6, 2011 | 01:37 PM
dlewis2583's Avatar
junkyard was closed yesterday because of the holiday...i'll have to run by thursday when im off...
305_DB7ish
Mar 16, 2015 10:34 AM
jaygood2go
Apr 2, 2013 08:14 PM
eg_junior
Jan 5, 2007 12:43 AM
spencedogg
May 19, 2003 11:11 AM
