Built GSR Turbo motor
Old Sep 3, 2011 | 10:36 AM
hybridpatient95's Avatar
Default Built GSR Turbo motor
:::FOR SALE:::
WILL SELL FULL LONG BLOCK FOR 2600$
WILL SELL CLUTCH AND TRANY FOR 1600$
CAR WAS TUNED BY JEFF EVANS IN PA. CAR MADE 668WHP ON PUMP GAS WITH A 40R AND A PRO-FAB RAM HORN MANIFOLD HAVE DYNO SHEETS TO PROVE MOTOR HAS ONLY ABOUT 3000 MILES!!!
1. JDM Type r tranny $1200
-quaiffe lsd
-carbon coated synchros
-heat treated gears
-freshly painted casing
-built by hondatahindu
-0 miles since build
2. Exedy hyper clutch (twin disc) $700
clutch set up (the purple one) including ARP flywheel pressure plate bolts and both discs for who doesnt know wahts included.
3. GSR block sleeved 2.0 b18c1 2000$$
-Aebs sleeves 84.5mm with matching main caps and girdle
-CP 9.0:1 pistons
-Eagle connecting rods
-Acl bearings
-Golden eagle 84.5mm headgasket
-Arp main bolts
rod bolts
head studs
-Moroso oil pan tapped with -10 fitting
-Gsr crank machined
polished
balanced
knife edged
-Type r oil pump
-Type r water pump
-Gsr timing belt
4. Gsr head worked all work on head done by M2RACE SYSTEMS 1000$
-race ported by m2 race systems
-3 angle valve joB by m2 race systems
-flow bench test by m2 race systems
-BC turbo cams
-BC +1mm valves
-BC springs and retainers and seats
-skunk 2 cam gears (blue)
I DONT WANNA PART THE LONG BLOCK REALLY UNLESS THE MONEY IS RIGHT BUT I WILL SELL EVERYTHING TOGETHER OR ILL SELL IN PIECES PLEASE DONT LOW BALL ME EVERYTHING IS LEGIT EVERYTHING HAS RECIEPTS THE WHOLE ENTIRE SET UP HAD OVER $14000 INVESTED SO IF YOUR A BROKE *** LOL KICK ROCKS
DONT WASTE MY TIME PLEASE TEXT ME 9084871848
Z0831xiz
Engine Machining & Assembly
Aug 29, 2016 08:31 PM
Honda_Fanatic
Nov 28, 2007 08:12 PM
Honda_Fanatic
Oct 26, 2007 07:01 PM
Honda_Fanatic
Oct 25, 2007 08:23 PM
