AR 1994 civic hatchback dx b16a/gsr tranny swap
Well I am putting my hatch back up for sell and with a lot of things swap and replaced..
You can contact me at 501-944-8062. I am up late so please feel free to text...I have a auto respond program If I am a sleep lol... This is not a riced out or raced car.. The muffler on the car is ever nice and quiet and all you can hear is motor.. It's really nice to be always to talk or just drive with out some loud fart can...
nothing like people thinking you have a d series lol
The good
1995 ex coupe chassis harness ( car is wired for vtec now)
Power windows
Power locks ( auto lock do work when using the key)
Power mirrors
Front/rear ex disk swap
Black civic door panels
Black inside door handles
Black power lock switch
Black power window switches
95 Integra front/rear floor mats
95 integra black gsr dash swap
95 integra gsr clock
95 Integra climate control
Gsr black leather front seat
JDM gsr cluster * with red led blubs*
Gsr black center console with leather armrest ( comes with spare cloth top)
2000 integra cd player with tape deck * have code* Cd player does work and read burned cd
Black rear civic hatch lower plastic panels
New 02 sensor * 1k on it*
clutch slave * 3k on it*
New Ignition lock assembly ( with spare key)
95 integra rear sway bar ( not installed)
Nue speed lowering spring
P2t intake manifold
P2t throttle cable *less then 2 months old*OEM honda part
P2t throttle stay* less then 2 months old* OEM honda part
ITR throttle body ( installed 7/13/2012 with new gasket
P2t Thermostat * less then 2 months old* OEM honda part
P2t thermostat housing *less then 2 months old* OEM honda
P2t water outlet * less then 2 months old* OEM honda part
P2t fan witch * less then 2 months old* OEM honda part
B series axles with 6k ( can be replaced with brand new if buyer wants. They have LTW)
Chipped p28 ( b16 base map stock rev and vtec at 5k)
Innovative a60 motor mounts *2k on them*
Gsr shift linkage
Stage 2 clutch
B16a
95 gsr tranny
Password jdm intake * less then 200 miles on it*
Password jdm lug nuts * less then 100 miles on them*
Spare b16/b18c valve cover
A/c * the car has a crv a/c bracket with a stock 92-95 a/c system. Needs a crv belt and charged*
B series crank pully
Coolant temp switches replaced
Konig forwards with brand new 205/50/15 ( 200 miles on them)
oem temp switches *installed 6/9/2012*
OEM Front speakers installed with oem tweeter
New ngk spark plugs ( installed 7/15/2012)
New ngk 7mm plug wires installed (8/10/2012)
Coal can and all vacuum lines are hooked up to oem spec
Spare b16a intake manifold with gsr fuel rail
Spare oem fuel pump
spare oem fuel float
Black civic front/rear carpet( installed 8/21/2012
custom painted throttle body,valve and fuel rail
New OEM fuel pump gasket ( installed 8/21/2012)
Camber kit /w no ball joints ( blox or skunk2 ball joints bolt into them and are from 60-85 shipped for a set)
Z6 uncut engine harness ( installed 8/5/2012)
Replacement tq mount with brand new oem nut,washer and body bolts (9/20/2012)
New oem map sensor crews (9.20.2012)
Black civic oem steering wheel with air bag
X2 not opened Itr throttle body gasket
Rear lower back seat installed ( waiting on integra rear upper part from a friend)
That is all I can think of.. I ran mobile 1 10/30 synthetic oil every oil change and ngk plugs..
Now for the bad about the car.
Leater seats need to be re-done
windshield needs replaced
needs paint
I have around 60,xxx miles on the motor now.. I have some other things planed for the car the longer I have it.. So price may go up pending what I do with the car...
The asking price is 3500 OBO
Thanks for checking this out.
Pictures of the outside of the car. Yes the front cap is white because the orange body parts needed replaced. They are all oem honda parts from a 95 ex coupe
The good
Power windows
Power mirrors
P2t intake manifold
Gsr shift linkage
Stage 2 clutch
B16a
95 gsr tranny
Spare oem fuel pump
needs paint
Black front/rear carpet with dc2 gsr floor mats.
Black steering wheel with jdm grs cluster with red leds and yes I have the gsr vent it just not in the car right now
Some shots of the engine and other stuff..... Yes the stock header got a little header paint on it lol
[URL=http://s245.photobucket.com/albums/gg65/freeclowns/1994%20civic%20hatch%20back/?action=view¤t=2012-06-17_02-34-26_910.mp4]
A pictures with the door panels on. If the car has not sold in the next couple weeks I will have integra door shell and panels installed in the car.. It will look factor and meet with the dash perfect..
