Suspension & Brakes Theory, alignment, spring rates....
NEEDED: Ground Control Spring Isolator Dimensions
Old Sep 2, 2011 | 05:52 AM
jaymua's Avatar
Default NEEDED: Ground Control Spring Isolator Dimensions
I'm cheap and do not want to spend $25/each for these.
Alternative: Energy Suspesion Poly Universal Coil Spring Isolators: $7-$20
http://www.energysuspensionparts.com...-Isolators.asp
*Would need dimensions for STYLE A isolator.*
Thanks!
Old Sep 3, 2011 | 09:07 AM
jaymua's Avatar
Default Re: NEEDED: Ground Control Spring Isolator Dimensions
Bump
Old Sep 3, 2011 | 10:02 AM
grumblemarc's Avatar
The Grumpiest
You have everything you need in front of you don't you?. Do you not have a caliper to measure the ID of the spring and the OD of the lip of the GC top mount? That's all you need to do at this point.
Old Sep 4, 2011 | 06:36 AM
jaymua's Avatar
Yes I could do that but still need middle circle and lip dimensions.
Old Sep 4, 2011 | 06:56 AM
The Grumpiest
What? If you have everything but the isolators you have the ability to measure everything you need to GET the right isolators. Why are you making it harder than it is?
Old Sep 4, 2011 | 10:51 AM
Andy@AMR's Avatar
I've got isolators in stock, how many do you need? They should work with your setup just fine. Our rubber isolators that we use on our coilovers should fit perfectly on the 2.5ID springs they use.
dcsports
Suspension & Brakes
11
Dec 31, 2016 08:57 AM
azzazel_99
Suspension & Brakes
31
Jun 21, 2012 09:42 AM
PassportBreh
Suspension & Brakes
Feb 6, 2012 02:12 PM
UsMcBaldie247
Suspension & Brakes
Oct 12, 2011 12:35 PM
enrique
Apr 28, 2003 12:09 PM
