cam question..
im a little confused here. Well im planning on doing a bisimoto cam on my d16z6. I will probably end up doing valve springs as well. I was also wondering if the whole timing belt assembly has to come apart. I am also due for a timing belt/water pump combo...
Can both be done at the same time? correct me if im wrong please.
I will probably end up getting my local performance shop to do the install.
Depending on how aggressive the cam is, you def will need to upgrade retainers/springs. And also, yes you can do both of those at the same time during the cam swap. You have to remove the belt anyways.
raverx3m
May 1, 2012 12:40 AM
sideswiped
Feb 7, 2009 09:48 PM
