Question About Suspension Tech Rear Sway Bar
Ok so i got it installed and its adjustable.. There are three holes on each side of the sway bar. Witch hole do i want it connected to for the most agressive handling???
A) Hole towards the front of the car?
B) Middle Hole?
C) Hole towards the back of the car?
Thanks
If I remember correctly. The FRONT most hole is the softest setting and as you go towards the back of the car, the bar will become stiffer.
What do you mean by "aggressive handling"? The rear bar is used to control understeer. If you get too "aggressive" on the settings, you will end up with oversteer.
zippo1130
15
Jan 15, 2008 07:45 PM
ntrinsik
Jun 17, 2003 06:28 PM
