89 CR-X Si
does anyone know what this is? it is on the back of an 89 Si gauge cluster I have and has a blue plug like the cruise control box and shift light box, it has no light bulb but has two wires tapping into the gauges
is there any possibility this box is what compensated for the 14inch rims the Si came with, meaning it tapped into the odometer (you can see a wire below the speedometer cable inlet) to give accurate speed and odometer readings?
CR-X didnt have cruise control unless aftermarket or dealer installed. my sedan has cruise and this def isnt a cruise box. cruise box has 4 wires and a lightbulb not 3 wires and two wires tapping into the gauges
The speedometer is cable driven - calibration is done inside the transmission with different size gears predetermined from the factory on the mechanical sender.
I dont think it would be. 88-89 the relay for the dimmer was actually built into the dimmer switch then in 90-91 when they made the switches smaller they made the dimmer relay a box that was wired into the dash harness but located on the side of the steering column
Canadian_EF
Aug 12, 2009 08:14 PM
jtmoney2002
12
Jun 6, 2008 11:56 AM
