fsft eg door panels, autometer pods/gauges
clean black/grey eg door panels. door panels their self are in good shape. the plastic handle and insert at once were painted blue but the owner before me paint over black, so its cracking some and underneath is blue so would just need cleaned off and re sprayed black.
$70 obo picked up
2 larger ( 2 5/8 i think) phantom gauges. both are mechnical no sending units. they are water temp and oil temp both lights work
$25 for both or $15 each
2 regular size (2 inch i think) ultra lite. oil pressure is mechanical worked fine in my coupe! has the copper line just need the fitting to run in block
$20 on the oil pressure
other gauge is volts gauge worked fine in old coupe $15
$30 for both together
i have 2 autometer eg gauge pods
triple pillar pod grey in color $20
other pod where heater vents are holds 2 gauges and 5inch tach $40
im in cincy ohio 513-403-9282 can ship, will have to add to cover that
$70 obo picked up
integranator
Feb 26, 2004 04:02 PM
