P0753 and flashing D4
Old Aug 31, 2011 | 11:25 AM
ClubDownforce's Avatar
Default P0753 and flashing D4
I have an 1997 Accord that the check eng lite came on and the D4 lite is flashing, the code that comes up is P0753. What should i try?
Old Sep 1, 2011 | 09:20 AM
h0p3l355dork's Avatar
Default Re: P0753 and flashing D4
Have you searched on the forum for what that code may mean? I think the FAQs also have a DTC list of codes: https://honda-tech.com/forums/honda-accord-1990-2002-2/check-engine-light-codes-cel-diagnostic-trouble-codes-dtc-malfunction-indicator-light-mil-1490107/ Usually flash d4 and that code indicates automatic transmission imminent failure.
Old Sep 2, 2011 | 03:36 AM
MAD_MIKE's Avatar
MM Gruppe B
Originally Posted by ClubDownforce
What should i try?
Find out exaclty what P0753 is. A quick search nets us. 'P0753....Shift Solenoid 'A' Electrical'.
Might want to find out where 'A' is located and check its wiring harness, connection, and the solenoids resistance values. May just be a bad connection, a damaged wiring harness, or a faulty shift solenoid.
Going out on a limb here, is your 3-4 shifting feeling not quite right?
nkuser
Nov 20, 2020 08:36 PM
HondaNigeria
Nov 27, 2018 06:36 PM
simplypinoyy
Apr 5, 2007 11:39 AM
dingusjt
Nov 7, 2003 07:45 AM
-KangaRod-
Oct 18, 2003 10:00 PM
