EP3 clutch questions
Old Aug 30, 2011 | 02:40 PM
granadablanca's Avatar
Default EP3 clutch questions
Hi all,
The original clutch on my wife's EP3 is finally nearing the end (one owner - 130,000 miles!), and I would like some opinions.
I just read through a thread here that was basically 3 pages of the OP being made fun of for paying $900 for a clutch job. So I guess I don't want to be that guy, but I didn't realize that price was so unreasonable.
Anyway, a few questions:
1) Is there an aftermarket setup that is just a tad heavier than stock? Neither of us like the mushy pedal of the stock clutch (even when it was new), and would like to find something a little firmer if possible. It doesn't need to actually grip harder or quicker - she won't be modifying the car and never races. It's purely a pedal feel thing.
I don't know what's good or bad on this car, and whether aftermarket is worth the expense. I have an Exedy racing clutch on one of my other cars, and she can't drive it whatsoever. I also notice every ACT seems to require a RSX Type-S flywheel as well. So maybe I should just forget this whole idea. Any advice?
2) What should I expect to pay for this in SoCal, by a non-shady shop? My regular guy, who I trust and I've previously verified all his other quotes to be fair, is telling me $800 (labor), $285 (clutch kit), $50 (flywheel resurface). This is over $1100. I called a couple other local shops, and they were all in the same general $1100-1200 range. Dealer was way worse still (obviously).
People in that other thread were bragging about having it done for $400 or less, which just sounds impossible to me. I've trusted this guy many times before, but there's a BIG difference between $400 and $1100. Does it have to do with location? If not, can anyone in SoCal recommend a good shop?
3) Finally, more generally, is there anything I should look out for or know about having this done? Presumably stock is the "best" way to go for normal commuter use, and I should forget about question 1? Any dos and don'ts? Anything that should be done while he's in there, etc? Any lightweight flywheel that's just so good I should get instead of resurfacing? Just trying to get all my ducks in a row.
Thanks guys!
Old Aug 30, 2011 | 08:55 PM
spatula's Avatar
Default Re: EP3 clutch questions
For a little stronger than stock your best bet is probably the RSX-S stock replacement clutch and flywheel. To run the RSX-S clutch you have to also use the flywheel, which I believe is lighter than the EP3's.
I have the RSX-S Exedy OEM replacement clutch and Competition Clutch 11.5lb lightweight flywheel. For a daily driver that setup works well for me, it sounds like stock Type-S flywheel would suit you just fine. The Type-S setup feels like what the clutch should have been to begin with, not anything extreme you need to adjust to.
I installed the clutch myself and I'm on the East Coast so I can't help with SoCal pricing. Check out clubEP3 or ephatch, there's a ton of Cali guys on there that could help with local pricing and shop recommendations. Also the cheapest place to get a clutch is Amazon. I was surprised as hell, my clutch was $117 shipped.
Old Aug 31, 2011 | 06:35 PM
Thanks! Will look into that. Amazon sells OE clutches, or off-brand? I never even thought to look there.
Also joined ephatch and asked there, thanks for that tip as well.
Old Sep 1, 2011 | 06:45 AM
turboteg2nv's Avatar
I'd look into getting a stainless steel braided clutch line. This helps with fluid expansion and gives the pedal a tighter feel, regardless of clutch type. These can be found on clubrsx.com for about $40.
Any aftermarket clutch on the EP3 requires the RSX-s flywheel, unless it's OEM.
You get what you pay for in terms of labor quality. Alldata says the clutch job on an EP3 calls for 8 hours of labor, and at $80/hr of labor costs, do the math..
For your needs it sounds like just a standard Exedy OE replacement is all you need. I wouldn't recommend a lightweight flywheel for normal daily driving if you won't be racing or doing any additional mods.
No it's not. Both are 16lbs.
DarkRattle
Transmission & Drivetrain
Jul 5, 2017 04:24 AM
I Am White
Feb 6, 2009 05:52 AM
hondafrk505
Jul 11, 2006 05:36 PM
Chris93Si
Mar 9, 2003 02:43 AM
StinkyTofu
May 20, 2002 05:11 PM
