89 sedan wire tuck, 5speed swap. help
Used the da pedal only problem I had was the hole on the gas pedal other then that it went right in. I have ran into a bit of a problem now I don't have a hole to run the clutch cable can anyone help me out on where I can put it? And i have a6 bottom z6 head combo motor to put in, do I need to get a z6 ecu and jumper harness or what?
Try this link for your clutch cable.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/need-run-my-clutch-cable-2829344/
although most people will just use the hole with the black cap in it with success - a little boring out with a drill or whatever to get the cable to slide through.
There are a few options for your ECU, but to make it easy and keep it clean then I would suggest you go with the Z6 ECU and convert to OBD1 (use the Z6 distributor, 4 wire O2 sensor, and OBD0-to-OBD1 jumper harness).
Don't forget that if you use the Z6 injectors you don't use a resistor box and if you use the A6 injectors you do need the resistor box.
Thanks man appreciate it ill check out that link. It's all z6 up on the head so ill most likely do the ecu and jumper. Can I use the z6 engine harness as well instead of running multi point wires all over
DPFI to MPFI is 4 additional wires.
2 more wires for your auto-to-manual swap (reverse lights)
http://nzhondas.com/tech-help/78416-...to-manual.html
If you want to do it REALLY clean you can get a complete engine harness from RyWire.
Question is, how often are you going to be popping your hood to stare at your wires?
DPFI to MPFI. fuel pump is kicking on, I am getting power, cluster lights arent turning on. and the motor doesnt wanna turn over at all? any one have any idea? i have been searching all morning i cant find a single thread thats like this.
fuel is pumping but the motor isnt turning. i put the key in and turn it over, it does nothing....
i got it to turn over, but the only way it will turn over is if i bump the starter with a screwdriver the ignition wont turn the car over, any ideas? only code im throwing is 21 something about vtec. pump is kicking on for fuel. not to sure on my spark yet. but i havent gotten any fault codes for it. (ground the thermostat to any bare metal right?)
its wanting to start but im not getting spark to any of my plugs. should there be a spring somewhere in the cap of the dizzy? if so its no there. could this be the reason why? DPFI to MPFI conversion but im almost positive its wire up right. button looks a little burnt any ideas on what to do next?
i dont think so i can check tho
i know i had a blue green or blue yellow one of them i had but the other one wasnt there. if that makes sense. on the write up it asked for both of them to be ran to c1 c2 i ran a solid blue one with the other one so i could of prolly have that wrong? im not exactly sure **** is so old the colors dont even look like real colors anymore alot of fading.
i have a a6 bottom z6 head on it. so shouldnt i need the spring? or how would i go about finding out what dizzy is on it as of now
appreciate the help man
things been a nightmare.
https://honda-tech.com/forums/showthread.php?t=2829344
just went through every single wire on the ecu and they all checked out and were the same wires and went to the right spots. all im missing is spark. how do i tell what dizzy i have?
technically on a z6 head you should have a TD42U. but either the TD41 and TD42 will work. they both have slightly different bolt patterns. TD42U is for sohc vtec head. my guess is for you to still go over your wiring. and make sure you have the correct firing order and the screw on the rotor is still on nice n tight.
