OK 95' Honda Civic Coupe DX
Old Aug 30, 2011 | 06:33 AM
dc2JDMwhore's Avatar
Default 95' Honda Civic Coupe DX
I bought this car April 1st 2009 completely stock, everything aftermarket was installed by me and a few friends. With a little TLC this car could be very nice. I'm just tired of investing more and more money into it and am bored with the car. Mainly looking for trades at this time.
Looking for a nissan 240sx sr20 swapped, but open to other offers. U2U me with pictures and offers.
YEAR/MAKE/MODEL: 1995 Honda Civic DX
CURRENT MILEAGE: Body-216,xxx Motor-112,xxx
COLOR: Granada black pearl, black interior
TRANSMISSION: 5 speed
LOCATION OF VEHICLE: Enid, Oklahoma
CONTACT VIA: PM me on here or ask for my number
PRICE: $4300 obo
Additional Information
CLEAN TITLE? Yes.
HISTORY OF ACCIDENTS? Have not car faxed, only thing I know of is when I was hit by a deer 2 years ago. Did damage to fender, door, and mirror. Was not reported.
HISTORY OF PAINT/BODYWORK? Core support has been replaced due to previous wreck/owner.
MAINTENANCE HISTORY & DO YOU HAVE DOCUMENTATION? Receipts for most of the parts I have purchased on the car. From Paypal, JHPUSA, Weaksauce..etc
CURRENT CONDITION OF WEARABLES INCL. TIRES, BRAKES, BELTS, HOSES, SUSPENSION COMPONENTS AND FLUIDS
Tires: 1500 miles
Belts: 2,000 miles
Hoses: look good, none have had to be replaced.
Suspenson: Bushings could used replaced in the front lca's
Fluids: All changed and topped off 2,000 miles ago
OIL: Changed 500 miles ago with mobil1 5w30 and honda filter
-Exterior
-Granada Black Pearl
-Front grill/fog lights cut out
-OEM factory painted license plate plugs
-Siebon CF Hood
-New Honda window seals
-Replica Spoon Mirrors
-Stanley clear corners
-Stanley jdm plastic headlights
-Mud flaps
-Type-R replica PU lip
-Slightly tinted taillights
-New front bumper "Not installed"
-Interior
-Front Black Integra seats "slight rip drivers side"
-Ex Clock
-Ex Cluster
-OEM civic floor mats
-DIY amber lights
-JDM Fog Light Switch
-Added Armrest
-Blox "490" Shift **** *electric blue*
-PwJdm Shift Boot
-Alpine Deck & Front door speakers
-No Power Anything *base model*
-Owners manual
-Suspension/Brakes
-Function/Form type 1 coil overs
-Function/Form black LCA's
-Skunk2 UCA's with new ball joints "upgraded style"
-ES tie rod/ball joint boots
-Rear ASR lower tie bar
-Front 3 point strut bar
-New Tie-rods *inner and outer*
-New lower ball joints
-No P/S *base model*
-ES bushing kit "not fully installed"
-Pwjdm front drilled/slotted brake rotors
-GSR rear disc swap
-40/40 prop valve
-New rear calipers, pads, & rotors
-5mm wheel spacers all around
-Polished Kosei K1's with new hankook tires
-Non abs 4 wheel disc brake booster, GSR master cyl. "not installed"
-Skunk2 rear camber kit "not installed"
-Engine/Transmission
-OBD2 ls swap (With VIN plates on engine and transmission)
-OBD1 alternator
-OBD1 GSR injectors
-OBD1 polished distributor
-Integra throttle cable
-Painted valve cover
-Ebay air intake with K&N filter
-RMF replica header
-Adjustable test pipe
-2 1/4 inch exhaust with stock or magnaflow muffler
-AEM red adjustable cam gears
-Exedy stg 1 clutch kit
-Fidanza 7.5lb flywheel
-ES shifter bushings
-Pwjdm cam seal
-Honda timing belt and water pump "3,000 miles ago"
-Honda oil pump "1,500 miles ago"
-New Honda coolant res.
-New CV axles
-New Fuel Filter
-New Pcv valve
-New Honda NGK plugs
-New plug wires
-New distributor cap/rotor
-PwJdm Res. Covers
-Slight Wiretuck
-Pwjdm radiator bracket
-New duralast gold battery
-New a/c compressor, belt, and Drier
-New compressor bracket "JDM del sol b16"
-Oil changed every 3k w/ mobil1 & honda filter
-Heater works great
-Everything is there for A/C
-Crank sensor removed and no lower timing cover.
BADS:
-Paint is faded, Passenger door has been spray painted after replacement, Fenders both need to be replaced (driver side is beat up pretty good).
-A/C stopped working randomly about 2 weeks after fixing it, Possible leak maybe. Ran very cold while running.
-Weird noise coming from the front end when I hit a bump and the rack wont align right, so the steering wheel is crooked.
-Climate control wont adjust from hot to cold
-No tint
NEW PICTURES:
9/1/11
OLD:
NEW:
Old Sep 1, 2011 | 10:35 AM
Default Re: 95' Honda Civic Coupe DX
bump
Old Sep 1, 2011 | 12:30 PM
the yoda's Avatar
bump for a good deal, wish i had the cash
Old Sep 2, 2011 | 05:11 AM
Thanks man.
BUMP
Old Sep 6, 2011 | 06:47 AM
bump
Old Oct 5, 2011 | 07:36 AM
bump! 4k this week
SLO_EH2
Feb 21, 2012 02:28 PM
SLO_EH2
Feb 10, 2012 07:01 PM
SLO_EH2
Feb 10, 2012 02:03 PM
fst teg 1
Mar 27, 2009 07:09 AM
jlsmi2
Jan 14, 2004 08:58 PM
