Skunk2 Tuner 1 Valvetrain?
Old Aug 29, 2011 | 11:27 PM
MistahJuice's Avatar
Default Skunk2 Tuner 1 Valvetrain?
Hey guys of been researching this for days and I just can't figure out what to do. After studying up on valvesprings I decided the supertechs were too high of a max lift and eventually decided to just go with s2 valve springs. on my B18C1. All i need to know now is retainers. This is a DD with some weekend autoxing, thats it. Redline won't be set any higher than 8500 max. I don;t want to use titanium retainers because I want to be able to slap em in there and forget about them for the most part and just check them after I go autoxing. This whole search has been quite demoralizing for me, I'm about to just go ITR cams instead lol.
Basically will oem retainers be reliable and last for a long period of time with the s2 springs or should I go with the BC chromoloy steel retainers. Thanks Also do you guys think I should use any other brand of valvesprings
Old Aug 30, 2011 | 02:12 PM
Skunk2Brian's Avatar
Default Re: Skunk2 Tuner 1 Valvetrain?
Technically upgraded valvesprings and retainers are only recommended for Tuner 1 camshafts, they are not required.
That being said your S2 spring / OEM retainer combo will be more than sufficient.
Old Aug 31, 2011 | 06:19 AM
95 integra's Avatar
I ran my old Skunk2 springs w/ OEM retainers for a few years and they worked flawlessly together.
Old Aug 31, 2011 | 09:10 PM
Thanks guys really helps, just wanted to make sure this setup would be reliable even when I'm autoxing in the upper rpm for a couple min.
Cimburke23
Dec 23, 2010 11:33 AM
GI8U2racing
22
Mar 12, 2008 09:05 PM
Speed_1
Aug 3, 2006 01:13 PM
vinasity
Jun 21, 2004 04:27 PM
ninjaman
Jul 17, 2001 05:24 PM
