'92 Accord H22 race harness
Okay, so, here it goes;
I race clay oval in a mini stock class. My car for next season will be an H22 swapped 1992 Honda Accord. I bought the car with the swap already done and wired up. Now what I plan on doing is eliminating all unecessary items out of the wiring harness to have the bare minimum required. Basically just power to the ECU.
I will have a seperate switch for; Fuel, fan #1, fan #2, alternator, sart, and power (for ecu). So all those components can be rulled out of the OEM harness.
I'm currently crew chief for my buddies H22 swapped '91 Prelude which already had a "race harness" made. Most would say; "Just copy it" but its easier said then done and wanted to start fresh with this harness.
Has anyone come to doing this before?
i dont know if this will help you but here you go anyway
http://www.ff-squad.com/technet/wiring.obd1.htm
and might wanna google it
I've been using that as my bible for this past race season and other car builds. But what I mean would be; Can I just run single wires from the ecu to for example; the TPS? MAP? etc? Or do they have to be all interconnected like they are currently from honda?
OutlawCL
Jul 29, 2004 08:40 PM
