Transmission Internal Interchangability
Old Aug 29, 2011 | 01:25 PM
homebuilt503's Avatar
Default Transmission Internal Interchangability
I have a lame 4 Spd. in my 91 hatchback. About a year ago I pulled an Si transmission but never used it because the the rear mount had ripped right off. (Head on collision doing 80+, wasn't my car or me driving)
What I'm wondering is could I take the housing/case from my 4 spd. and move the Si drivetrain into my 4 spd. That way I could safely mount it, I don't have a welder, don't know how to weld and don't want it welded to make this work.
Thanks for the help guys!!
Old Aug 29, 2011 | 03:48 PM
Default Re: Transmission Internal Interchangability
Almost 50 views and not a bite?? Looks like I'm finding out myself. lol
Old Aug 29, 2011 | 04:09 PM
4drEF's Avatar
Keyboard Humorist
Cases should change right over.
However, it may depend on the years - probably won't matter, but it 'may'.
88 is a weirdo year so that's my concern. You didn't say what years your two transmissions were.
BTW: you should consider new shaft and diff bearings and seals while you do this.
Also invest in a set of proper ring pliers to deal with the clip as it's usually a pain with the wrong tools.
Old Aug 29, 2011 | 09:22 PM
I thought the same, but I'm positive that both are 89-91 trannies.
Old Aug 30, 2011 | 12:22 AM
hatchet_honda's Avatar
80mph and you were still able to get the trans outta that wreckage?? holy crap.. as far as awitching cases itll work fine. only diff if it was an 88 is the input shaft. otherwise casings wont be an issue
Old Aug 30, 2011 | 06:08 AM
jlicrx's Avatar
yes, swap the entire Si gearset into the 4-speed case - you will need to use the differential carrier from the 4-speed and bolt the Si ring gear to it since the 4-speed uses the 35mm carrier bearings and the Si uses the 40mm bearings
Old Aug 30, 2011 | 11:04 AM
Cool cool, yea I will start doing this sometime next week or so. I might as well just rebuild this thing since I will have it out. Never rebuilt a tranny before, but I am mechanically inclined to perform one. What would be common seals, bearings, ect to replace since I will have the whole tranny open?
Again thanks for your guys replies.
Old Aug 30, 2011 | 11:51 AM
Nooch's Avatar
Damn, 80 head on. Guessing whoever was the driver got launched out of the windshield.
Old Aug 30, 2011 | 12:00 PM
Yea its pretty crazy. I bought the cars as a parts car from a tow company. The driver who was at the scene said the kid was speeding through the forest, lost control at about 80 mph. Driver broke collar bone, passenger slammed there head through the sunroof and cracked it significantly. (There skull I'm assuming as well)
Thats what you get for being a dumbass. It will never make sense to me. LOL
silas871
Apr 16, 2013 09:29 AM
2008fijibluesi
Audio / Security / Video
15
Sep 14, 2009 06:16 AM
realfasthonda
17
Jan 15, 2004 10:53 AM
cmy-vtec
Dec 26, 2003 11:51 PM
Tuned1.5LVtec
May 26, 2003 06:23 PM
