D15b oil consumption,burning issues
Old Aug 28, 2011 | 10:36 PM
tico's Avatar
Default D15b oil consumption,burning issues
whats up guys i swapped in a used d15b and have had a noticeable increase in oil consumption and burning. sometimes smokes at cold start up or right after an oil change, smokes at high rpm stationary or under load and when im also driving in the hills at inclines.. did compression and leakdown. comp good across the board as well as leakdown.. now i have a feeling it could be valve seals but not to sure.. i dont know if it makes a difference but the engine came out of an auto and i swapped it into a manual..
Old Aug 29, 2011 | 06:00 AM
sde780's Avatar
Default Re: D15b oil consumption,burning issues
Sounds like valve seals if it smokes after you leave it off for a while
jonyi27
Apr 21, 2014 11:55 AM
SpeedMachine
Apr 29, 2005 12:27 AM
opiumdaze
Apr 23, 2005 02:20 PM
Jeff
Apr 18, 2005 06:23 AM
AMChev
Sep 15, 2002 10:26 AM
