1979 cbx
Old Aug 28, 2011 | 08:57 PM
Nikos's Avatar
Default 1979 cbx
I run into this bike. Interesting enough in 1979 honda had to make a statement with v6 superbike running 4 cams 24 valves.
Honda CBX
Year: 1979
Category: Sport touring
Rating: 74.8 out of 100. Show full rating and compare with other bikes
Engine and transmission
Displacement: 1046.00 ccm (63.83 cubic inches)
Engine type: In-line six, four-stroke
Power: 105.00 HP (76.6 kW)) @ 9000 RPM
Top speed: 220.0 km/h (136.7 mph)
Compression: 9.3:1
Bore x stroke: 64.5 x 53.4 mm (2.5 x 2.1 inches)
Valves per cylinder: 4
Fuel control: DOHC
Cooling system: Air
Gearbox: 5-speed
Transmission type,
final drive: Chain
Chassis, suspension, brakes and wheels
Front tyre dimensions: 3.50-19
Rear tyre dimensions: 4.25-18
Front brakes: Dual disc
Rear brakes: Single disc
Physical measures and capacities
Weight incl. oil, gas, etc: 274.0 kg (604.1 pounds)
Fuel capacity: 24.00 litres (6.34 gallons)
On google.com I found a few sales at 16k for bikes at excellent condition.
This one is showing 1600 miles original miles
Just nuts, this is the kind of honda that one day might bring their R line to the USA.
Cliff Notes
Museum bike found
guy wants $8000
THE END _
Old Aug 28, 2011 | 09:01 PM
Nikos's Avatar
Default Re: 1979 cbx
the cams used some short of coupler to act like a dual overhead cam
Old Aug 29, 2011 | 02:43 AM
TheTurbinator's Avatar
Nice
Old Aug 29, 2011 | 02:48 AM
ragnaroek's Avatar
cthulward
i was about to call BS on the quad cam statement. I had no idea they used 4 cams and some couplers.... i wonder why they did that.
Old Aug 29, 2011 | 02:51 AM
Nikos's Avatar
they probably didnt want the cam to deflect too much or there was some other kind of a design limitation.
Old Aug 29, 2011 | 04:21 AM
ragnaroek's Avatar
cthulward
i guess it was a manufacturing limitation.
The camshafts are in the normal places. The two exhaust cams, like the two inlets, are joined together by an Oldham coupling. The longer the camshaft the more difficult it is to keep it true during the grinding and heat-treating procedures. The CBX's cams, were they onepiece, would be very long-thus the Oldhams.
Old Aug 29, 2011 | 06:18 AM
scartail's Avatar
I6, right? not a V6. I saw one a couple months ago at the local bike rally. It sounded fabulous!!!
Old Aug 29, 2011 | 10:15 AM
Stinkycheezmonky's Avatar
Suspetise...
I6, correct. Neat bike, but this:
is just...
Old Aug 30, 2011 | 04:58 PM
The_Head's Avatar
CBX's are straight pimp. I thought about buying one but I would have to shoot myself if I dropped it, or wrecked it. The same thought applies to a first gen Goldwing.
Old Aug 31, 2011 | 01:19 PM
Nikos's Avatar
the admin of the cbx forum was able just by the pics to let me know that this 79 has a 81 engine so I guess it is not 100% original
TXcivic96
Honda Motorcycles
40
Mar 11, 2006 01:33 PM
sinfultrends
Aug 4, 2004 12:25 PM
Bruce Leeroy
Aug 3, 2004 07:21 AM
c-rex
Honda Motorcycles
May 14, 2001 06:33 PM
