d15b2 to sohc zc wireing
Old Aug 28, 2011 | 02:46 PM
dspeedcrazy02's Avatar
Default d15b2 to sohc zc wireing
i have a 91 civic with a d15b2 that i swaped a sohc obd0 zc into. i bought a obdo si harness and the large connector on the driver side does no fit and there is an extra connector on the passenger side by the fuse box. what do i have to do to modify the connector by the driver side, and what is the spair connector. im so close to this swap being done yet far. has anyone done this swap with this set up,what did you do??????
Old Aug 28, 2011 | 03:03 PM
xero_xero's Avatar
Default Re: d15b2 to sohc zc wireing
it sounds like a dpfi to mpfi swap.
did you maintain the b2 intake?
there are plenty of write ups of this swap.
i will post up pics of the crx that i have sitting to identify Mpfi harness plugs.
I do believe they are plug and play as long as you have a manual. it seems you may have an automatic harness.
Old Aug 28, 2011 | 03:38 PM
the guy i bought it from said that it was from a 5 speed. everything matches and fits except the end connector on the driver side, and the extra connector. the zc that i bought has the multi point mani on it and the si harness matches the injectors distributer ect... the connector on the dx chassis has more wires than the si harness so i cant just swap over the old b2 connector.
Old Aug 28, 2011 | 04:03 PM
JDpower's Avatar
Dude you can't just expect to plug it in and work with your DX cabin harness. You use the si harness for certain plugs and then you add wires to your existing DX harness (injectors/ dizzy). Search for DPFI to MPFI write-ups.
Nooch
May 27, 2010 09:55 PM
tjscivic
Aug 28, 2009 10:18 AM
devonb456
Jan 17, 2009 02:50 PM
Wuffio
Oct 10, 2008 08:31 PM
mxjosh
Aug 19, 2008 05:47 AM
