FS: Fresh Vitara D16z6 Block, D16z6 VTEC Head
Block is fresh out of the machine shop and has been sitting on my engine stand ever since.
Don't mind the red stuff that's actually Torco MPZ Engine Assembly Lube HP.
D16z6 bare block with crank, main girdle, and new set of OEM main bolts - I spent over $450 for the machine work alone. Asking $325.00 PICK UP ONLY
(P2W clearance is set to .003".)
- Block was overbored .20 over to 75.5mm and given a fresh hone
- Hot tanked
- Resurfaced deck for flatness
- Notched the block and the girdle to clear rods
- Crank has been micropolished and cleaned
I have a few OEM D16z6 parts left.
- New OEM oil pickup and OEM oil pickup gasket - $25.00 shipped
- New OEM oil pan gasket - $15.00 shipped
- New OEM timing belt pulley + guides (Part number - 13621-PM9-A03 and 13622-PM3-020) - $15.00 shipped
The D16z6 head should probably take it in for a rebuild. Perfect time those stiff springs and a big cam.
Stock D16z6 VTEC head (Purchased from a DSO member) - $100.00 PICK UP ONLY
Stock port
Stock valves
Includes VTEC solenoid, full valvetrain (rocker arms, etc.), cam, and valve cover
Doesn't include the cam gear
At the moment I am only shipping the smaller parts and asking that the block and head be picked up only. I will ship only to the lower 48 states.
- Hot tanked
Stock port
Stock valves
Thanks man, this setup does have potential. Did it right with 75.5mm pistons so you don't need to deal with piston slap or a big P2W clearance. Like I said I'll flex a little bit with pricing so if your serious PM me.
GLWS BRO
