LMA mod problems obd0 b16a
Old Aug 28, 2011 | 08:14 AM
claymonthug's Avatar
Default LMA mod problems obd0 b16a
i put prelude lma's in my b16a with a .042 inch washer under them and my engine still taps. it sounds worse now then it did before i did this mod. anyone else experience this with their engines?
Old Aug 28, 2011 | 08:26 AM
PandaEj6's Avatar
Default Re: LMA mod problems obd0 b16a
Where did you purchase the lma's?
Sounds almost as if you dont have h22 lma's and you shimmed b16/gsr/itr lma's and now the clearances are too tall.
Heard of other problems w/ people trying to shim h22 lma's into their b16 head using the washer. People I heard of who took the old ones & new ones to a machine shop so they can make sure the height is exact never had an issue.
Look into it...its just a thought
Old Aug 28, 2011 | 08:35 AM
iv done my time. i have the lude LMA's part no. ending in 003.
the lmas did not come with a washer on the bottom of the spring.
i used 8 washers all exactly the same size. .042
adjusted valves. still taps like crazy
Old Aug 28, 2011 | 08:40 AM
PandaEj6's Avatar
That sound like a headache. Goodluck man
Old Aug 28, 2011 | 10:31 AM
help?
Old Aug 28, 2011 | 01:19 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
What did you set the valve lash to? What made you think you needed to mess with the LMAs in the first place?
Old Aug 28, 2011 | 05:43 PM
FIXED
nevaeva,
i wouldnt say that i NEEDED them but for preventative maintenance i figured id replace them. and i also like a quite car.
i adjusted my valves a few times before and i could still hear a significant amount of taping. after i took the old ones out there were a couple that the 'piston' would stick down on.
Old Aug 28, 2011 | 05:53 PM
by the end of replacing them i just wanted to get it over with. also there was a hurricane about to hit the east coast and i just wanted to get home. i just flew threw the adjustment but was pretty confident that it was right.
it definitely was not tho.
intake is exactly .006
exhaust is .007
RanCRX
Mar 11, 2013 04:01 PM
racereaper7
Sep 2, 2012 06:15 PM
1320king
Sep 9, 2009 04:33 PM
ComeOnKip
Oct 8, 2008 11:04 AM
austrian type-R
Jul 4, 2002 11:54 PM
